Kasa Filament Smart Bulb, Warm Amber
Control from Anywhere
Control your LED filament smart bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Turn your lights on and off from the office, check in and make sure you turned off your kitchen lights, even schedule lights to turn on before you get home.
Warm Amber
The glow of the Kasa Filament Smart Bulb, Warm Amber illuminates a 2000K light that is suitable for homes, restaurants, cafes and wherever a warm, romantic ambiance is desirable.
Dimmable
Kasa Smart’s LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. From entertaining guests to a romantic dinner, this bulb can dim to fit any environment.
No Hub Required
The Kasa Filament Smart Bulb, Warm Amber connects directly to your home’s secure WiFi network. No need for a hub or extra equipment. All you need is your smartphone, the Kasa Smart app and a WiFi connection to start remotely controlling your smart bulb.
Device Grouping
Use Grouping to combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap of your smartphone. Put all of your amber lights into a single group and dim them all at once for the perfect romantic dinner lighting.
Voice Control
Use simple voice commands to control your Kasa Filament Smart Bulb with any Alexa or Google Assistant. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Energy Monitoring
Using the Kasa Smart app, you can check on your LED filament bulb from anywhere to see how much energy is being consumed. Turn it off remotely to stop any consumption.
Set Schedules
Use your Kasa Smart app to schedule your LED filament light bulb to turn on and off around your daily routine.
Quick and Easy
Be up and lit with your new smart bulb! It’s as easy as 1-2-3 or A-B-C! Screw your bulb in, follow the simple setup in the Kasa Smart app, name it and get to glowing.
Dimmable
Kasa Smart's LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. From entertaining guests to a romantic dinner, this bulb can dim to fit any environment. -
Device grouping
Use Grouping to combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap of your smartphone. Put all of your amber lights into a single group and dim them all at once for the perfect romantic dinner lighting. -
Voice control
Use simple voice commands to control your Kasa Filament Smart Bulb with any Alexa or Google Assistant. Just tell your voice assistant to dim your lights and set the perfect mood for movie night. -
Energy monitoring
- TP-Link Kasa Smart KL60 - LED filament light bulb
- Light Source Type
- Shape
- A60
- Socket Type
- E27
- Wattage
- 5 W
- Colour of Illumination
- Amber light
- Colour Temperature
- 2000 K
- Luminous Power
- 450 lumens
- Beam Angle
- 290 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Kasa
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Warranty
- 2 year warranty
Light Source
- Shape
- A60
- Socket Type
- E27
- Wattage
- 5 W
- Energy Consumption per 1000h
- 5 kWh
- Amber light
- 2000 K
- Colour Rendering Index
- 80
- Luminous Power
- 450 lumens
- Beam Angle
- 290 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Switch Cycles
- 15000
- 1%-100% dimmable, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, light scheduling
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Kasa
- Communications Type
- Cloud
- Wi-Fi
- Intelligent Assistant Compatible
- Voice Controlled
- Indirect
- Package
- Box
- RoHS
- Diameter
- 60 mm
- Length
- 120 mm
- -15 °C
- 40 °C
