TP LINK KL50B Filament Smart Bulb (white) - Bayonet B22
Quicklinx: FM44WS00 Mfr#: KL50B
Control from Anywhere
Control your LED filament smart bulb from anywhere with the Free Kasa Smart app (iOS, Android).
Soft White
Kasa Filament Smart Bulb, Soft White’s 2700K temperature works well for any environment. Adjust your light to any level of brightness for the right ambiance.
Dimmable
An expansive dimming range that can be controlled conveniently with the Kasa Smart app.
No Hub Required
Connects directly to your home’s secured Wi-Fi network. No need for a hub or extra equipment.
Device Grouping
Combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap on your smartphone.
Voice Control
Use simple voice commands with Alexa and Google Assistant to dim your lights and set the perfect mood for movie night.
Energy Monitoring
Track the real-time energy consumption with the Kasa Smart app.
Set Schedules
Use your Kasa Smart app to schedule your LED filament light bulb to turn on and off at set times throughout the day.
  • Control from anywhere
  • Dimmable
  • Device grouping
  • Voice control
TP-Link Kasa Smart KL50B - LED filament light bulb - shape: A60 - B22 - 7 W - soft white light - 2700 K
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/691059
Light Source Type
Shape
A60
Socket Type
B22
Wattage
7 W
Energy Efficiency Class
E
Colour of Illumination
Soft white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
290 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Kasa
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Light Source
Shape
A60
Socket Type
B22
Wattage
7 W
E
Energy Consumption per 1000h
7 kWh
Soft white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
800 lumens
Beam Angle
290 degree(s)
Warm-Up Time
1 sec
Dimmable
Switch Cycles
15000
1%-100% dimmable, Android compatible, iOS compatible, light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.14 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Kasa
Wi-Fi
Voice Controlled
Indirect
RoHS
Diameter
60 mm
Length
120 mm
