TP LINK KL50 Filament Smart Bulb (white) - Screwfit E27
Quicklinx: FM42WS00 Mfr#: KL50
Type: Light bulb
Compatible With: Google Assistant, Alexa
£12.49 ex VAT
£14.98 inc VAT
Express delivery Order within the next 22 hours for delivery on Thursday
Control your LED filament smart bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Turn your lights on and off from the office, check in and make sure you turned off your kitchen lights, even schedule lights to turn on before you get home.
Kasa Filament Smart Bulb, Soft White's 2700K temperature works well for any environment. Dim your light to any level of brightness for the right ambiance for a multitude of occasions. The dimmer the bulb, the more you can see the filament design inside.
Kasa Smart's LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. Turn your filament bulb to full brightness for a well-lit vanity or dim it down for a dinner party.
  • Control from anywhere
  • Soft white
  • Dimmable
  • No hub required
    The Kasa Filament Smart Bulb, Soft White connects directly to your home's secure Wi-Fi network. No need for a hub or extra equipment. All you need is your smartphone, the Kasa Smart app and a Wi-Fi connection to start remotely controlling your smart bulb.
  • Device grouping
    Use Grouping to combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap of your smartphone. Put all of your Kasa Smart light bulbs into a single group and dim them all at once for the perfect ambiance.
TP-Link Kasa Smart KL50 - LED filament light bulb
Light Source Type
Shape
A60
Socket Type
E27
Wattage
7 W
Colour of Illumination
Soft white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
290 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Kasa
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Light Source
Shape
A60
Socket Type
E27
Wattage
7 W
Energy Consumption per 1000h
7 kWh
Soft white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
800 lumens
Beam Angle
290 degree(s)
Warm-Up Time
1 sec
Dimmable
Switch Cycles
15000
1%-100% dimmable, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
Kasa
Communications Type
Cloud
Wi-Fi
Intelligent Assistant Compatible
Voice Controlled
Indirect
Package
Box
RoHS
Diameter
60 mm
Length
120 mm
-15 °C
Type: Light bulb
Compatible With: Alexa
Brand: TP LINK
Stock Status: In stock
