Create an immersive or fun ambiance to your home with rich color patterns and brilliant lighting effects.
Endless lighting effects
Pick from dozens of animated lighting effects from soothing "Raindrop" to the dazzling "Rainbow". -
Scenes
Bring an immersive or fun ambiance to your movie night. Create your own scenes however you wish. -
Easy setup
Stick, plug in and connect. The flexibility to bend, cut and extend allows you to add them to the exact place you desire. -
Grouping
Combine your light strip with other Kasa Smart devices for seamless control with a single tap on your smartphone. -
Voice control
Use simple voice commands to control your light strip with Alexa or Google Assistant.
- TP-Link Kasa Smart - light strip extension - LED - multicolour light - 2500-9000 K
- Product Type
- Light strip extension
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/696109
- Light Source Type
- LED
- Usage Modes
- Rainbow, raindrops
- Energy Efficiency Class
- F
- Colour of Illumination
- Multicolour light
- Colour Temperature
- 2500-9000 K
- Luminous Power
- 700 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 120 V
- Designed For
- Kasa Smart KL430
- Product Type
- Usage Modes
- Extendable, flexible, cuttable, lighting schedules, 16 colour zones
Light Source
- LED
- Built-in LED Lamp
- F
- Energy Consumption per 1000h
- 8 kWh
- Multicolour light
- 2500-9000 K
- Luminous Power
- 700 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 120 V
- Power Consumption Stand by
- 0.3 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Kasa Smart
- Supported Host Device Platform
- Android
- Wi-Fi
- Voice Controlled
- Indirect
- UL, FCC
- Warranty
- 2 years
- Length
- 1 m
- Shipping Dimensions (WxDxH) / Weight
- 19.5 cm x 6.6 cm x 14.5 cm
- -20 °C
- 40 °C
- Designed For
- TP-Link Kasa Smart KL430
