Designed for workgroups and departments, T2500G-10TS provides full set of Layer 2 management features. It delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Gigabit switches and high-speed servers.
Abundant L2 features
T2500G-10TS supports a complete lineup of L2 features. In addition, the switch provides advanced features for network maintenance. IGMP throttling & filtering restricts each subscriber on a port level to prevent unauthorized access. -
Secure networking
The T2500G-10TS provides advanced security to protect against broadcast storms, ARP attacks, and more. Moreover, the switch supports 802.1x authentication, which is used in conjunction with a RADIUS server to require some authentication information before access to the network is allowed. -
Advanced QoS features
To integrate voice, data and video service on one network, T2500G-10TS supports rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means, to ensure that voice and video are always clear, smooth and jitter free.
- TP-Link JetStream T2500G-10TS - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 2 x Gigabit SFP
- Performance
- Bandwidth: 20 Gbps , Packet forwarding rate: 14.9 Mpps
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP, SSH, SSH-2, CLI
- Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, VCT technology, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, DAI, fanless, LACP, Port Security, IP-MAC binding, SNMP trap, GARP, GVRP
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.3av
- Power
- AC 120/230 V (50/60 Hz)
- 29.4 cm x 18 cm x 4.4 cm
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 8K entries
- 9KB
- Encryption Algorithm
- TLS 1.0, SSL 3.0, SSL 2.0
- Authentication Method
- RADIUS
- 8 x 1000Base-T RJ-45 , 1 x console RJ-45 , 2 x 1000Base-X SFP , 1 x console (micro-USB)
- Power Device
- Internal power supply
- Voltage Required
- 8.38 watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- FCC
- 29.4 cm
- 18 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
