TP LINK JetStream 8-Port Gigabit Smart PoE+ Switch
Quicklinx: CMCGWS00 Mfr#: T1500G-10MPS
TP-Link JetStream Gigabit Smart Switch T1500G-10MPS is equipped with 8 gigabit RJ45 ports and 2 SFP slots, all RJ45 Ports support the 802.3af/at (PoE+) standard with total PoE power budget of 116W and useful PoE power management features. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-Link's JetStream Gigabit Smart Switch T1500G-10MPS is especially designed for the small and medium business networks that require effi­cient network management. T1500G-10MPS comes with a comprehensive set of features, such as Link Aggregation Group, 802.1Q VLAN, Access Control Lists (ACL), Quality of Service (QoS L2 to L4), Storm Control and IGMP Snooping to provide a small or medium-sized business with a network that is geared for growth while ensuring performance and reliability. What's more, its easy-to-use web management interface means faster setup and configuration with less downtime, providing the ideal solution for your business network.
  • IEEE 802.3at/af-compliant Power over Ethernet
    The T1500G-10MPS supports 8 ports of IEEE 802.3af/at-compliant PoE and has a total power supply of 116W to power any 802.3af/at-compliant power device. It's an effi­cient and cost-effective choice to work with wireless access points, surveillance cameras, IP phones and other PoE supported devices, while getting rid of cables or power lines running around. Compact and flexible, the T1500G-10MPS is ideal to flexibly use PoE to deploy wireless access points or IP-based network surveillance cameras for projects or small business networks.
  • Advanced QoS features
    To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including Port Priority, 802.1P Priority and DSCP Priority, to ensure that voice and video are always clear, smooth and jitter free. In conjunction with the Voice VLAN the switch supports, the voice application will operate with much smoother performance.
  • Abundant Layer 2 features
    For more application of layer 2 switches, T1500G-10MPS supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, Port Isolation, Port Mirroring, STP/RSTP/MSTP; Link Aggregation Control Protocol and 802.3x Flow Control function. Any more, the switches provide advanced features for network maintenance such as Loop Back Detection, Cable Diagnostics and IGMP Snooping. IGMP Snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling & -filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
  • Enterprise Level Management features
    T1500G-10MPS is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or industry-standard Command Line Interface (CLI). SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
TP-Link JetStream T1500G-10MPS - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
116 W
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.9 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, RMON, SNMP 3, SNMP 2c, TFTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), DoS attack prevention, WRR queuing, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, bandwidth control, LACP, Port Security, 512KB packet buffer, CoS, tagged VLAN, 802.1x authentication, DSCP support, Storm Control
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
29.4 cm x 18 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
116 W
Performance
8K entries
Jumbo Frame Support
9000 bytes
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
RADIUS
8 x 1000Base-T RJ-14 , 2 x Gigabit LAN SFP
Internal power supply
4 rubber feet
Rack Mounting Kit
Included
FCC, RoHS
29.4 cm
18 cm
4.4 cm
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
