TP LINK JetStream 48-Port Gigabit Smart PoE Switch
Quicklinx: CMCCWS00 Mfr#: T1600G-52PS (TL-SG2452P)
T1600G-52 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface(GUI) or SNMP and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
TP-LINK JetStream Gigabit Smart Switch T1600G-52 is a cost-effective product solution for small and medium-sized business which provides high performance, powerful L2 and L2+ features like static routing, enterprise-level QoS and useful security strategies. Equipped with 48 gigabit RJ45 ports and 4 SFP slots, T1600G-52 supports multiple useful features. Static Routing helps route internal traffic for more efficient use of network resources. The Storm Control feature protects against Broadcast, Multicast and Unknown unicast Storm. Quality of service provides enhanced traffic management capabilities to move your data smoother and faster. Moreover, the easy-to-use web management interfaces, along with SNMP, RMON and Dual Image, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive L2/L2+ switch and gigabit capability, TP-LINK JetStream Gigabit Smart Switch T1600G-52 provides you the ideal access-edge solution.
  • Robust security
    Equipped with Secure Shell (SSH) and Secure Shell version 2 (SSH2) authentication methods, alongside SSL encryption, the TP-Link JetStream T1600G-52PS ensures secure network environments. Its Access Control List (ACL) support further enhances security, allowing for detailed access control.
  • High capacity networking
    With a switching capacity of 104 Gbps and forwarding performance of 77.4 Mpps, this switch is designed to handle the demands of growing businesses. Its capacity for up to 4000 VLANs makes it ideal for complex network environments.
  • Efficient power management
    The TP-Link JetStream T1600G-52PS features Power over Ethernet Plus (PoE+) across 48 ports with a total power budget of 384 W, facilitating flexible installation of PoE devices such as IP cameras and wireless access points without the need for additional power supplies.
  • Advanced network features
    This switch supports a range of advanced features including Quality of Service (QoS) for traffic prioritization, port mirroring for monitoring network traffic, and dual image support for redundant firmware images, ensuring smooth and reliable network operations.
  • Comprehensive standards compliance
    Compliant with a wide range of IEEE standards, the TP-Link JetStream T1600G-52PS supports various networking protocols and features such as IGMP snooping, Spanning Tree Protocols (STP, RSTP, MSTP), and VLANs, ensuring compatibility with existing network infrastructures.
TP-Link JetStream T1600G-52PS - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
384 W
Performance
Switching capacity: 104 Gbps , Forwarding performance: 77.4 Mpps
ACL entries: 300 , IPv4 routes (static): 32 , IGMP snooping groups: 256 , Virtual interfaces (VLANs): 4000
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Flow control, BOOTP support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, Cable Diagnostics Function, bandwidth control, IP-MAC binding, SNMP trap, DHCP client, Neighbor Discovery Protocol (NDP), port isolation, Loopback, DiffServ Code Point (DSCP) support, 3 fans, system log, ARP inspection, dual image support, Head-of-line (HOL) blocking
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 33 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP / 7 / 8
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
384 W
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, TLS, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
48 x 1000Base-T RJ-45 PoE+ , 4 x SFP
Internal power supply
470.4 Watt
Rack Mounting Kit
Included
FCC
44 cm
33 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
