TP LINK AV600 PT Powerline Starter Kit
Quicklinx: CMBBWS00 Mfr#: TL-PA4010P KIT V2.20
Type: Bridge
Speed: 500Mbps
Connectivity: Wired
45 on order, no confirmed delivery date
£25.59 ex VAT
£30.70 inc VAT
The TL-PA4010P turns your existing power line into a high-speed network with no need for wires or drilling. No configuration is required, simply plug your adapter into your power socket and you can establish a networking infrastructure in a flash. With fast speeds, the TL-PA4010P is a great choice for the implementation of a multimedia entertainment network.
  • Fast speeds
    With advanced technology, the TL-PA4010P can provide users with stable, high-speed data transmission rates. The TL-PA4010P is a great choice for a whole home solution to connect all network compatible devices.
  • Better performance
    The TL-PA4010P can optimize power line communication performance by suppressing noise interference generated by surrounding electronic equipment that can affect network performance.
  • Extra power socket for additional devices
    With its integrated power socket, the TL-PA4010P provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the adapter.
  • Pair button for easy network security
    Simply by pushing the pair button on the adapter, users can set a hassle-free network, complete with secure encryption.
TP-Link Powerline AV500 - V2.2 - Passthrough Starter Kit - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, HomePlug AV
9.5 cm x 5.8 cm x 4.2 cm
France
Bridge
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, Plug and Play, FCC, RoHS
Status Indicators
Power, LAN, link/activity
Line Properties
Line Coding Format
OFDM
LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x HomePlug AV - power 2-pole
1 x network cable - 2 m
France
Software Included
Drivers & Utilities
9.5 cm
5.8 cm
4.2 cm
10 - 90% (non-condensing)
Type: Bridge
Speed: 500Mbps
Connectivity: Wired
Brand: TP LINK
Price Range Ex VAT: 0 - 50
