TP LINK AV600 Powerline Extender 3 Pack
Quicklinx: CJMLWS00 Mfr#: TL-WPA4220T KIT V1.20
  • IEEE 802.11n
  • One Touch Super Range Extension - Wi-Fi Clone Button simplifies your Wi-Fi configuration and helps build a seamless unified home network
  • HomePlug AV standard providing up to 600Mbps1 high speed data transmission over a home’s existing electrical wiring, ideal for lag-free HD or 3D video streaming and online gaming
  • Extend 300Mbps wireless connections to previously hard-to-reach areas of your home and office
What This Product Does
TP-LINK’s TL-WPA4220T KIT extends your Internet connection to every room of the house through your home’s existing electrical circuitry. The TL-WPA4220 features a Wi-Fi Clone Button enabling Super Range Extension, which means it can automatically copy the SSID and Password of your router. In this way, TL-WPA4220T KIT simplifies your Wi-Fi configuration and allows for seamless roaming within your home network.
With a Wi-Fi Clone Button enabling Super Range Extension, the TL-WPA4220 can automatically copy the wireless network name (SSID) and Password of your router at the push of a button. After pressing the button, you can place the powerline adapter anywhere you want wired or wireless access and enjoy seamless networking across your entire home or office.
Up to 600Mbps - Ideal for HD Video Streaming
With advanced HomePlug AV technology, TL-WPA4220T KIT provides you with stable, high-speed data transfer rates of up to 600Mbps on a line length of up to 300 meters. It is a great choice for a whole home solution to connect all network compatible devices - from computers, game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Extend Wi-Fi Coverage to Every Room
With wireless speeds of up to 300Mbps, you can effortlessly extend your Wi-Fi network via the existing powerline and broadcast a wireless signal to share with all your Wi-Fi enabled devices in another area of your home or office.
Plug and Play
You can set up a hassle-free Powerline network within minutes with TP-LINK’s powerline adapters, just plug in and play. Also, the adapters’ "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
  1. Plug one Internet connected adapter into a nearby power outlet.
  2. Connect additional adapters to PCs/laptops/Internet TVs or other networked devices via an Ethernet cable or Wi-Fi - and you're done!
  • One touch super range extension
    With a Wi-Fi Clone Button enabling super range extension, the TL-WPA4220 can automatically copy the wireless network name (SSID) and Password of your router at the push of a button. After pressing the button, you can place the powerline adapter anywhere you want wired or wireless access and enjoy seamless networking across your entire home or office.
  • Ideal for HD video streaming
    With advanced HomePlug AV technology, TL-WPA4220T KIT provides you with stable, high-speed data transfer rates over a household electric circuit for up to 300 meters. It is a great choice for a whole home solution to connect all network compatible devices - from computers, game consoles to set-top boxes for IPTV to printers and NAS hard drives.
  • Extend Wi-Fi coverage to every room
  • Plug and Play
    You can set up a hassle-free Powerline network within minutes with TP-LINK's powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
TP-Link Powerline AV600 - V1.20 - Network Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
600 Mbps
WMM support, QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV
9.4 cm x 5.4 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2003, Microsoft Windows 2000/XP/Vista/7/8
United Kingdom, Europe
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
600 Mbps
Max Range Indoors
300 m
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, 128-bit AES, WPA2-PSK
WMM support, QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, FCC, RoHS
Status Indicators
Power, LAN, link/activity
Line Properties
Line Coding Format
OFDM
LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x HomePlug AV
12.916 watt
1 x network cable - 2 m
9.4 cm
5.4 cm
4 cm
10 - 90% (non-condensing)
