New, Smaller Design
TP-LINK's TL-PA211 powerline adapter takes advantage of your home's existing electrical wires to transfer data while simultaneously transferring traditional power.
That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and instantly establish a networking infrastructure.
With high-speed data transfer rates of up to 200Mbps, users can enjoy HD video streaming, online gaming, VoIP or any other bandwidth intensive tasks for work or play.
Super Small Design
With its new ultra-compact housing design, TP-LINK's TL-PA211 is much smaller than most other 200Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it nearly blends completely in front of any power outlet.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-PA211 provides users with stable, high-speed data transfer rates of up to 200Mbps on a line length of up to 300 meters.
Together with its built-in Qos and powerful AES encryption, the TL-PA211 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
Twin Pack Design
A PLC (powerline) connection is established by transmitting data through the electrical wires between two outlets, so it requires at least two PLC adapters plugged into those two outlets to complete the network.
With twin pack design, the starter kit is ideal for new users establishing their first PLC network or experienced users intent on expanding their networks.
Reduces Power Consumption Up to 65%
The TL-PA211, a new-generation Powerline Adapter, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters.
When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 65%*.
*Actual data will vary because of the network conditions and environmental factors
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection, It's that simple!
- Plug the adapter into the power outlet
- Connect the device via the network cable to the adapter
- Press the encryption buttons--and you're done!
Super small design
With the ultra compact housing design, TP-Link TL-PA211 is much smaller. With its thick feature and high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room. -
Stable, high speed data transfer rate
The TL-PA211 provides you stable, high-speed data transfer rate. The TL-PA211 is such a good choice for a whole home solution to connect all network compatible devices - from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives - and supplies them with broadband Internet. -
Twin pack design
The PLC connection is transmitting the data through the electric wire between two outlets, so it at least requires two PLC adapters plugged into the outlet to transform the data streaming. With twin pack design, the starter kit ensures to establish a powerline network for the first time. -
Power saving
With its logical practical product design and sophisticated power-saving mode, the TL-PA211 consumes less power when compared with existing powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular working mode to power-saving mode that will reduce the energy consumption.
- TP-Link TL-PA211KIT AV200 Mini Powerline Starter Kit - bridge - desktop
- Bridge
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 200 Mbps
- TCP/IP
- Quality of Service (QoS)
- IEEE 802.3, IEEE 802.3u, HomePlug AV
- Power
- AC 120/230 V
- 5.6 cm x 9.3 cm x 3 cm
- System Requirements
- Apple MacOS, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
- Bridge
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 200 Mbps
- TCP/IP
- Encryption Algorithm
- 128-bit AES
- 1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
- Voltage Required
- AC 120/230 V
- 3 Watt
- 5.6 cm
- 9.3 cm
- 3 cm
- Cables Included
- 2 x network cable
- Plug and Play, CE, FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 10 - 90%
