What happens when your wireless signal is too weak to connect to an access point in another building and you want to better position your wireless antenna in a higher or wider place to get a better signal?
The antenna extension cable is the answer to your problems. There is no need to move your access point or wireless router, which may sometimes be immovable, from place to place.
- TP-Link TL-ANT24EC12N - antenna extension cable - 12 m
- Antenna extension cable
- Length
- 12 m
- Connector
- N-Series connector - male
- Connector (Second End)
- N-Series connector - female
- Network Cable Type
- Impedance
- 50 Ohm
- Length
- 12 m
- Connector
- -10 °C
- 60 °C
