TP LINK AC50 Wireless Controller
Quicklinx: FT8CWS00 Mfr#: AC50
Auto-detect and centralized management, up to 50 CAPs
License-free management reduces the OPEX of enterprise network
Easy deployment without changing the existing network topology
Unified configuration of wireless networks, support mapping of SSID and VLAN
Support MAC authentication, portal authentication
Dual-link back up for management safety.
  • Efficient management
    Designed to handle up to 50 manageable access points, the AC50 Wireless Controller offers a scalable solution for growing businesses, ensuring seamless connectivity across the network.
  • Comprehensive compatibility
    With support for Mac, PC, and Unix systems, this network management device ensures wide-ranging compatibility, making it a versatile choice for diverse IT environments.
  • Enhanced security
    Featuring robust authentication methods including RADIUS and SSID, along with WPA and WPA2 encryption algorithms, the AC50 Wireless Controller provides a secure network environment to protect sensitive data.
  • Advanced networking features
    Supports multiple SSID, SSID to VLAN mapping, VLAN, and Wi-Fi Multimedia (WMM), coupled with fanless design, firmware upgradability, load balancing, and system log capabilities for optimized network performance.
  • Reliable operation
    Operates within a wide range of temperatures from 0°C to 40°C and humidity levels from 10 - 90% (non-condensing), ensuring dependable performance in various environmental conditions.
TP-Link AC50 Wireless Controller - network management device
Network management device
External
Ports Qty
5
Ethernet, Fast Ethernet
Manageable access points: 50
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
20.9 cm x 12.6 cm x 2.6 cm
20.9 cm
12.6 cm
2.6 cm
External
Ports Qty
5
Wired
Load balancing, VLAN support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Multiple SSID support, fanless, system log, SSID to VLAN mapping
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.1x
5 x 100Base-TX - RJ-45
FCC, RoHS
Internal power supply
5 Watt
