TP LINK 8-Port Gigabit Desktop PoE Smart Switch
Quicklinx: FNDCWS00 Mfr#: T1500G-10PS(TL-SG2210P)
TP-LINK T1500G-10PS switch is equipped with useful PoE power management features. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
  • Advanced QoS features
    Integrate voice, data and video service on one network, the switch applies rich QoS policies. The administrator can designate the priority of the traffic based on a variety of means.
  • Abundant layer 2 features
    The switches provide advanced features for network maintenance such as cable diagnostics and IGMP snooping. IGMP snooping ensures the switch intelligently forward the multi-cast stream only to the appropriate subscribers.
  • Management features
    T1500G-10PS is easy to use and manage. It supports various user-friendly standard management features.
TP-Link JetStream T1500G-10PS - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
53 W
Performance
Switching capacity: 20 Gbps , Forwarding performance: 14.9 Mpps
VLAN IDs: 4000 , Simultaneous VLANs: 512
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, STP support, RSTP support, MSTP support, ACL support, fanless, LACP support, LLDP support, CoS, DSCP support, Storm Control, LLDP-MED
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
20.9 cm x 12.6 cm x 2.6 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
53 W
Performance
8K entries
Jumbo Frame Support
9KB
Encryption Algorithm
SSL
Authentication Method
RADIUS
8 x 1000Base-T RJ-45 PoE , 2 x 1000Base-X SFP
64.9 watt
FCC
20.9 cm
12.6 cm
2.6 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
