TP LINK 24-Port 10/100 4 x Gigabit or 2 SFP Slot Managed Switch
Quicklinx: 895BWS00 Mfr#: TL-SL5428E
Designed for workgroups and departments, TL-SL5428E from TP-link provides full set of Layer 2 management features. It delivers maximum throughput where you need it - to high-performance workgroups at the edge of the network, or as a backbone for Fast Ethernet switches and high-speed servers in demanding small networks. Moreover, TL-SL5428E switch also comes equipped with 2 combo SFP slots, giving you greater network flexibility.
This TP-link L2 managed switch has robust security and management features. For workgroup and departments requiring cost-sensitive Layer 2 switch, and additional Gigabit capability, TP-link L2 fully managed switch TL-SL5428E can provide you the ideal access-edge solution.
  • Non-blocking switching
    The TP-link fully managed L2 switch TL-SL5428E provides non-blocking switching solution for a 10/100 Fast Ethernet connection. As to the switching capacity, TL-SL5428E has a non-blocking aggregated bandwidth of 12.8Gbps. It provides 24 10/100Mbps ports and 4 Gigabit 10/100/1000BASE-T ports. In these Gigabit copper ports, two of these ports are combo Gigabit ports, which will be disabled if the corresponding 1000BASE-X SFP slots are used. It can give you greater network flexibility.
  • Virtual stackable
    IP clustering allows up to 32 TL-SL5428E switches to be managed by a single IP, regardless of geographical locations. With all units identified by a single IP address, the stack could be configured, monitored, maintained as a single object. Traffic running across units in this virtual stack utilizes full-duplex interfaces and network wires, eliminating costly and cumbersome cables, minimizing the impact of any single point of failure.
  • Comprehensive security strategy
    The TL-SL5428E switch supports 802.1x authentication, which is used to require some authentication information before access to the network is allowed. And more, it enables the non-802.1x clients to access the specific network resource. Regarding to the Dos defending, TL-SL5428E provides you some typical Dos attacks to select. You can protect these attacks more easily ever than before. TL-SL5428E will provide you robust security to the network.
  • Enterprise level manageability and resiliency
    TL-SL5428E supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) or industry-standard Command Line Interface (CLI), either administration traffic can be protected through SSL or SSH encryptions. This sharing of vital management information saves time and money. With link aggregation, spanning tree protocol and virtual stack, a highly intelligent and scalable topology could be established, fulfilling the enterprise customers' requirement of building a unified, resilient network.
  • Optimized voice and video applications
    To integrate voice, data and video service on one network, TL-SL5428E applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means, so voice and video are always clear, smooth and jitter free. For other multimedia-on-demand application provides advanced features for easy stream management.
  • Resiliency and availability
    Link aggregation (LACP) increases aggregated bandwidth, optimizing the transport of business critical data. IEEE 802.1s multiple spanning tree, provides high link availability in multiple VLAN environments. It supports IEEE 802.1d/w Spanning Tree (STP/RSTP).
TP-Link TL-SL5428E - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Fast Ethernet
Ports
24 x 10/100 + 4 x 10/100/1000 + 2 x shared SFP
MAC Address Table Size
8K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
Auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 120/230 V (50 - 60 Hz)
44 cm x 26 cm x 4.4 cm
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8K entries
Routing Protocol
Authentication Method
RADIUS
Status Indicators
Power, link/activity
24 x 100Base-TX RJ-45 , 4 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 2 x SFP (mini-GBIC)
Internal power supply
FCC
44 cm
26 cm
4.4 cm
10 - 90% (non-condensing)
