Outdoor omni-directional antenna TL-ANT2415D operates in the 2.4-2.5 GHz band and provides 15dBi omni-directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the N female connector guaranteeing wider compatibility with most of the wireless equipments. Also, the weather proof design ensures that it can work normally for various demanding outdoor solutions.
The Outdoor Omni-Directional Antenna emits a powerful amplified signal over a 360 degree radius, delivering a strong multidirection signal from an Access Point or a Bridge. If you have multiple locations or buildings where you would like to integrate your wireless network, simply place the TL-ANT2415D in between the buildings with your Acess Point. It is most effective when placed at the top of buildings.
Easy To Use
Installation of the TL-ANT2415D is simple and straight forward. It is compatible with most wireless devices (Access Points, Routers, Bridges and Network Adapters) on the market with removable external antennas.
Enhanced connectivity
Equipped with MIMO technology, this antenna ensures a more reliable and efficient communication channel for outdoor Wi-Fi applications. -
Durable design
Designed to withstand the elements, the weatherproof feature of this antenna makes it suitable for outdoor placement without the worry of damage from harsh weather conditions. -
Versatile mounting options
With options for pole mounting, the TL-ANT2415MS offers flexibility in placement, ensuring optimal positioning for maximum signal strength and coverage. -
Broad frequency range
Catering to a wide frequency range of 2.3 - 2.7 GHz, this antenna is capable of delivering improved performance across various Wi-Fi spectrums. -
Directional coverage
Featuring a directional design with a gain of 15 dBi and horizontal and vertical beamwidths of 120° and 90°, it focuses the signal in specific directions for enhanced point-to-point communication.
- TP-Link TL-ANT2415MS - antenna
- Product Type
- Antenna
- 13.3 cm x 5.7 cm x 70 cm
- 3.5 kg
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, pole mount
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.3 - 2.7 GHz
- Gain
- 15 dBi
- Directivity
- Directional
- Product Type
- Antenna
- 13.3 cm
- 5.7 cm
- 70 cm
- 3.5 kg
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.3 - 2.7 GHz
- Gain
- 15 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.8:1
- Horizontal Beamwidth
- 90°, 120°
- Vertical Beamwidth
- 90°, 120°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x RP-SMA
- Weatherproof, MIMO technology
