The TL-MC1400 14-slot rack-mount chassis is specially designed to accommodate 14 TP-Links media converters for central power supply, saving space and power cables. Moreover, to stabilize the performance and extend the lifetime, two cooling fans are installed internally. Together with MC series Gigabit/Fast Ethernet media converters, TL-MC1400 is the ideal solution for your media conversion network.
- TP-Link TL-MC1400 - modular expansion base
- Modular expansion base
- Form Factor
- Rack-mountable - 2U
- Power
- AC 120/230 V (50/60 Hz)
- 48.2 cm x 35.8 cm x 8.6 cm
- 8 kg
- Designed For
- P/N: TL-SG3210XHP-M2 V2.6, TL-SG3452XP V1
- Height (Rack Units)
- 2U
- Installed Modules Qty (Max)
- 0 (14)
- 48.2 cm
- 35.8 cm
- 8.6 cm
- 8 kg
- Form Factor
- Rack-mountable
- Expansion Bays
- 14 (total) / 14 (free) x hot-swap
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
TP LINK TP-Link MC200CM - fibre media converter - 1GbE | In Stock | £28.80 |
TP LINK 1000M RJ45 to 1000M Single-Mode SC Fiber Converter | In Stock | £23.36 |
TP LINK 1000M RJ45 to 1000M SFP Slot Supp. MiniGBIC Modules Adapter | In Stock | £15.56 |
