TP LINK 10Gbase-SR SFP+ LC Transceiver  850nm Multi-mode  LC duplex
Quicklinx: BLZ3WS00 Mfr#: TXM431-SR
The TXM431-SR is designed to extend transfer distances based on 10 Gbps Ethernet connectivity. It is a 10GBASE-SR high performance 850 nm multi-mode SFP+ transceiver. It supports full duplex, 10G Ethernet connections up to 300 m or 33 m with 50/125 µm or 62.5/125 µm fiber cables respectively.
TP-Link TXM431-SR - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Full duplex capability
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
FCC
70 °C
10 - 90% (non-condensing)
