TP LINK 100M Fiber Converter 100M RJ45 to multi-mode SC Converter
Quicklinx: 7HZSWS00 Mfr#: MC100CM
The MC100CM is a media converter designed to convert 100BASE-FX fiber to 100Base-TX copper media or vice versa. Designed under IEEE 802.3u 10/100Base-TX and 100Base-FX standards, the MC100CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC100CM supports longwave (LX) laser specification at a full wire speed forwarding rate. It works at 1310nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required)or with TP-LINK's 19''system chassis, Auto MDI/MDI-X for TX port, Auto negotiation of duplex mode on TX port, and front panel status LEDs. The MC100CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 2 kilometers.
TP-Link MC100CM - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC multi-mode
External
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
9.5 cm x 7.3 cm x 2.7 cm
External
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Collision status, port duplex mode, power, link/activity
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - SC multi-mode
FCC
External power adapter
9.5 cm
7.3 cm
2.7 cm
10 - 90%
