TP-Link's TL-SM321B adopts the latest standard 1000Base-BX, transmission over a single strand of fiber, with one different wavelength going in each direction. You can extend the network distance up to 10Km with TP-Link's routers, switches, media converters to provide high speed and stability.
- TP-Link TL-SM321B - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC/UPC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-BX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 (TX) / 1550 (RX) nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- Designed For
- P/N: TL-SG3452XP V1
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-BX
- 1GbE
- 1.25 Gbps
- 10 km
- IEEE 802.3z
- 1 x Ethernet 1000Base-BX - LC/UPC single-mode
- Compatible Slots
- 1 x SFP (mini-GBIC)
- Plug and Play, FCC
- 0 °C
- 70 °C
- 10 - 90%
- Designed For
