TP LINK 100-240V Redundant Power Supply
Quicklinx: BLZ2WS00 Mfr#: TL-MCRP100
The TP-LINK Redundant Power Supply Module TL-MCRP100 is an AC-input and DC-output power supply module. It can convert 100-240V 50/60Hz input voltage into 9.5VDC output with rated wattage of 102W. The power supply module supports output over-voltage/short circuit/over-current protection. TL-MCRP100 is applicable to 14-Slot Rackmount Chassis TL-MC1400.
TP-Link - power supply - hot-plug / redundant
Power supply - hot-plug / redundant - plug-in module
Output Voltage
9.5 V
P/N: TL-MC1400
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
Output Voltage
9.5 V
10 - 90% (non-condensing)
P/N: TL-MC1400
