The 2.5GbE USB-C to Ethernet Adapter by StarTech.com provides a reliable and efficient way to connect to wired networks with ease. This adapter supports data transfer rates of up to 2.5 Gbps, making it suitable for high-speed Internet connections. Designed with an integrated USB-C cable that is 15.2 cm long, it is compact and easy to use, allowing for seamless connectivity with compatible devices. The device features an RJ-45 female connector, making it compatible with various Ethernet types, including 2.5GBase-T and Gigabit Ethernet.
Equipped with impressive specifications, this network adapter supports Jumbo frame sizes of up to 16,000, enhancing network performance. It's built to withstand a range of environmental conditions, operating between 0°C and 45°C and within a humidity range of 10 - 85% RH, ensuring robust performance under various scenarios. Additionally, this adapter is compliant with multiple standards, including FCC, RoHS, and WEEE, affirming its adherence to safety and environmental regulations, making it a reliable choice for networking needs.
High-performance connectivity
This adapter delivers data transfer rates of 2.5 Gbps, ensuring fast and reliable connections for demanding applications. It supports multiple data link protocols, including Ethernet and Fast Ethernet. -
Robust design for durability
Built to operate in temperatures ranging from 0°C to 45°C, this adapter is designed to withstand various environmental conditions, making it suitable for different networking scenarios. -
Versatile compatibility
Equipped with an RJ-45 connector, this adapter can connect to different Ethernet standards, such as 10M, 100M, 1G, and 2.5G, providing users with flexibility for their networking needs. -
User-friendly features
The adapter supports auto-negotiation and features Wake On LAN (WOL) capabilities, enhancing usability and ensuring efficient operations for end-users. -
Standards compliant
This product meets several compliance standards, including FCC, RoHS, and WEEE, ensuring it adheres to safety and environmental regulations for peace of mind.
- StarTech.com 2.5GbE USB-C to Ethernet Adapter - network adapter - USB-C 3.2 Gen 1 / Thunderbolt 3 - 10M/100M/1G/2.5 Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- Ports
- 2.2 cm x 1.5 cm
- 18 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 16000
- Processor
- Realtek Semiconductor RTL8156BG
- IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x, IEEE 802.3bz
- Space grey
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/activity, speed
- Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, Thunderbolt compatible, auto-negotiation
Processor / Memory
- Processor
- 1 x 2.5Gb Ethernet - RJ-45 - female
- Cables Included
- 1 x USB-C cable (integrated) - 15.2 cm
- MTBF
- 1,912,948 hours
- RoHS, WEEE, FCC, RCM
- Space grey
- OS Required
- 2.2 cm
- 1.5 cm
- 18 g
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1.6 cm
- Shipping Weight
- 24 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% RH (non-condensing)
StarTech.com USB-C to Ethernet Adapter | In Stock | £21.38 |
