Add an RS232 DB9 or DB25 serial port to your laptop or desktop computer with this Plug-and-Play USB to Serial adapter cable.
The ICUSB232DB25 3-foot USB to RS232 Serial adapter cable lets you connect 9-pin (DB9) or 25-pin (DB25) RS232 serial devices to your laptop or desktop computer through a USB port, as though the computer offered an onboard serial port.
This high quality USB/RS232 Serial adapter cable is a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
- StarTech.com USB to Serial Adapter - 3 ft / 1m - with DB9 to DB25 Pin Adapter - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232DB25) - serial adapter - USB 2.0
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Grey
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wired
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x RS-232 - 25 pin D-Sub (DB-25)
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Grey
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 90%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.75 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.25 |
StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F | In Stock | £6.54 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.32 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.33 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £49.60 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £108.11 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £102.11 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £175.88 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.35 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.29 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £244.59 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £392.42 |
