StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M
Quicklinx: 76MKWS00 Mfr#: ICUSB232DB25
Length: 1m
Hurry, only 2 left in stock!
£15.32 ex VAT
£18.38 inc VAT
Add an RS232 DB9 or DB25 serial port to your laptop or desktop computer with this Plug-and-Play USB to Serial adapter cable.
The ICUSB232DB25 3-foot USB to RS232 Serial adapter cable lets you connect 9-pin (DB9) or 25-pin (DB25) RS232 serial devices to your laptop or desktop computer through a USB port, as though the computer offered an onboard serial port.
This high quality USB/RS232 Serial adapter cable is a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
StarTech.com USB to Serial Adapter - 3 ft / 1m - with DB9 to DB25 Pin Adapter - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232DB25) - serial adapter - USB 2.0
Serial adapter
External
Interface (Bus) Type
USB 2.0
Grey
Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Serial adapter
External
USB 2.0
Wired
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x RS-232 - 25 pin D-Sub (DB-25)
1 x USB 2.0 - 4 pin USB Type A
Grey
Additional Requirements
USB port
60 °C
0 - 90%
76MK StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.75
76MK StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £33.25
76MK StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F In Stock £6.54
76MK StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £15.32
76MK StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.33
76MK StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £49.60
76MK StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £108.11
76MK StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.05
76MK StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £102.11
76MK StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £175.88
76MK StarTech.com USB to RS232 Serial Adapter In Stock £16.35
76MK StarTech.com 4 Port USB to Serial Hub In Stock £79.29
76MK StarTech.com 4-Port USB to Serial Adapter In Stock £244.59
76MK StarTech.com 8-Port USB to Serial Adapter In Stock £392.42
Length: 1m
