StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable
Quicklinx: 8FHYWS00 Mfr#: ICUSB2328I
Type: Serial adapter
Compatibility: PC, Mac
Interface: USB 2.0
£152.14 ex VAT
£182.56 inc VAT
Add 8 DIN Rail-mountable RS232 Serial ports to any system through USB. The ICUSB2328I Industrial 8-Port USB to Serial Hub with DIN Rail Clips converts a single USB port into eight RS232 serial ports, enabling you to connect to, monitor and control your serial devices.
Featuring rugged metal construction, with sturdy wall-mounting brackets and top-hat DIN Rail clips (included), this 8 port USB to RS232 Serial Hub provides versatile mounting options and a robust solution for both harsh industrial environments and simple desktop installations.
This USB powered adapter also retains assigned serial COM port values once connected, allowing the same values to be automatically reassigned to the USB serial hub ports.
  • Robust connectivity
    Equipped with eight 9-pin D-Sub (DB-9) male ports, this adapter facilitates connections to multiple RS-232 serial devices effectively, supporting diverse applications.
  • Versatile mounting options
    This adapter can be easily mounted on walls or DIN rails, providing flexibility for installation in various environments without compromising on accessibility.
  • High data transfer rate
    Achieving a data transfer rate of up to 921.6 Kbps, this adapter ensures quick and reliable data transmission, making it ideal for time-sensitive applications.
  • User-friendly design
    The USB-powered feature and included mounting kit simplify setup, while status indicators for port status, transmit, and receive enhance usability by providing clear operational feedback.
  • Compliance and safety
    Compliant with FCC and RoHS standards, this adapter meets regulatory requirements, assuring users of its safety and environmental responsibility.
StarTech.com 8 Port USB to Serial RS232 Adapter - Wall Mount - Din Rail - COM Port Retention - FTDI USB to DB9 RS232 Hub (ICUSB2328I) - serial adapter - USB 2.0 - RS-232 x 8
Serial adapter
DIN rail mountable
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 8
9.72 cm x 17.35 cm x 4.32 cm
950 g
RS-232
Data Transfer Rate
921.6 Kbps
FTDI FT232RL
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
DIN rail mountable
USB 2.0
Ports
RS-232 x 8
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Port status, transmit, receive
USB powered, wall mountable, DIN rail mountable
Processor / Memory
FTDI FT232RL
8 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB-A to USB-B cable (external) - 1.83 m
Mounting Kit
Included
FCC, RoHS
Power adapter - external
Software Included
Drivers & Utilities
9.72 cm
17.35 cm
4.32 cm
950 g
55 °C
5 - 95%
8FHY StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £22.01
8FHY StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
8FHY StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
8FHY StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £91.11
8FHY StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £152.14
8FHY StarTech.com USB to RS232 Serial Adapter In Stock £16.69
8FHY StarTech.com 2m Black DB9 Null Modem Cable In Stock £4.34
8FHY StarTech.com 16-Port USB-Serial Adapter Hub In Stock £415.42
8FHY StarTech.com 4 Port USB to Serial Hub In Stock £78.99
Compatibility: PC
Compatibility: Mac
Interface: USB 2.0
