This Right Angle DB9 to DB9 Serial Cable Adapter features one Right Angled DB9 Male serial connector and one standard DB9 female serial connector - a convenient solution for connecting serial devices where connection space around the DB9 port is limited.
Please note: there are two variations of this product, positioned differently to allow for easier connections based on the direction of right angle needed.
Versatile connectivity
The Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F facilitates seamless connection between serial devices. Its unique right-angle design ensures an efficient use of space, making it ideal for setups with limited room. -
Robust compatibility
Designed to support PC compatibility, this adapter ensures a reliable connection between a wide range of devices, enhancing the versatility of your serial connections. -
Quality assurance
Adhering to RoHS compliant standards, this serial cable adapter underscores a commitment to environmental responsibility and user safety, while maintaining high performance.
- StarTech.com Right Angle DB9 to DB9 Serial Cable Adapter Type 2 - M/F (GC99MFRA2) - serial adapter - DB-9 to DB-9
- Serial adapter
- 90° connector
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Grey
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2324852, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, ICUSB422
- Serial adapter
- 90° connector
- Grey
- Connector
- RoHS
- Designed For
