StarTech.com USB-C to VGA, DVI or HDMI
Quicklinx: CKQHWS00 Mfr#: CDPVGDVHDB
31 in stock
£39.22 ex VAT
£47.06 inc VAT
Keep this compact converter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This 3-in-1 travel adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI, or HDMI display.
The travel adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This travel adapter comes with a built-in black USB-C cable and works well with your Dell XPS, MacBook and any device that supports USB-C DP alt mode.
Instead of carrying three separate video adapters in your laptop bag, this 3-in-1 adapter gives you all the video outputs you'll need. With VGA, DVI and HDMI outputs, this adapter lets you connect from your laptop's USB Type-C port to almost any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a small-footprint design, this adapter is the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office.
The adapter features a built-in cable fastener. Simply tuck the cable into place along the side of the adapter for quick and secure storage while you're traveling to ensure the adapter is neatly stored in your travel bag.
The HDMI output on this travel adapter supports Ultra HD 4K resolutions, providing four times the picture quality of high-definition 1080p. The HDMI output is also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support high-definition maximum resolutions of up to 1920 x 1200, so you can still enjoy excellent video quality.
The travel adapter is compatible with USB Type-C Intel Thunderbolt 3 devices that are capable of outputting a DisplayPort signal.
StarTech.com USB C Multiport Adapter - UHD 4K - USB C to VGA / DVI / HDMI - USB C Adapter - USB-C VGA Multiport Adapter (CDPVGDVHDB) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
HDMI , DVI-I (dual link) , VGA
6 cm x 11 cm x 1.8 cm
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200
USB powered
1 x USB-C cable - 9 cm
6 cm
11 cm
1.8 cm
67 g
Enclosure Colour
Limited warranty - 3 years
CKQH StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.80
CKQH StarTech.com 6 ft DVI-D Single Link Cable - M/M In Stock £6.85
CKQH StarTech.com 15 ft DVI-D Single Link Cable - M/M In Stock £13.69
CKQH StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.99
CKQH StarTech.com 10 ft DVI-D Single Link Cable - M/M In Stock £7.97
CKQH StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.66
CKQH StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.20
CKQH StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £5.13
CKQH StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £50.42
CKQH StarTech.com USB-C Multifunction Adapter 4K In Stock £47.48
CKQH StarTech.com USB C Multiport Video Adapter – Aluminum – USB-C to VGA/HDMI/Mini DisplayPort/DVI Adapter –Display Adapter (CDPVGDVHDMDP) - external video adapter In Stock £53.53
CKQH StarTech.com USB-C to VGA Adapter with PD In Stock £30.79
CKQH StarTech.com USB-C to VGA, DVI or HDMI In Stock £39.22
CKQH StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £45.51
CKQH StarTech.com USB-C Multiport Adapter - DVI In Stock £48.66
CKQH StarTech.com USB-C Multiport Adapter - HDMI In Stock £48.65
Price Range Ex VAT: 0 - 50
