StarTech.com USBC Multiport Adapter 4K 60Hz
Quicklinx: GTB7WS00 Mfr#: 115B-USBC-MULTIPORT
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
More than 50 In Stock
£45.76 ex VAT
£54.91 inc VAT
This USB-C Multiport Adapter with DP 1.4 Alt Mode supports 4K 60Hz HDMI (HDR) and turns your MacBook, Dell XPS, or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features a 4K HDMI video output, three USB 3.2 Gen 1 Type-A (5Gbps) ports, SD and MicroSD card readers and a Gigabit Ethernet port, all through one connection to your laptop's USB-C, USB4, or Thunderbolt 3/4 port. Plus, it offers advanced charging and flexibility through a shared USB-C Power Delivery 3.0 and Data port which can be used to connect peripherals, with USB 2.0 transfer speeds (480Mbps), when a power source is not connected. The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more set up flexibility.
  • Enhance Productivity
    The portable docking station enables you to connect a 4K 60Hz HDMI monitor (4096 x 2160p), or an ultrawide monitor, to your laptop, to create a powerful workstation.
  • Connect Your Devices
    The USB-C to USB 3.2 Gen 1 hub features three USB-A (5Gbps) ports for connecting your USB devices.
  • Multiple Use Cases
    A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom, and is portable enough to be carried in your bag or backpack for mobile use. This lightweight USB-C Adapter can operate with bus-power alone, or use the USB-C port to connect a USB-C power adapter for laptop charging. Alternatively, use the USB-C port to connect additional peripherals at USB 2.0 speeds.
  • Built-In SD and MicroSD Card Readers
    Access your multimedia content with ease. The Multiport Adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards.
  • Charge Your Laptop
    With support for USB Power Delivery 3.0 pass through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop, when connected to a USB-C power source. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
StarTech.com USB C Multiport Adapter, 4K 60Hz HDMI Video, 3 Pt 5Gbps USB-A Hub, 100W Power Delivery Pass-Through, GbE, SD/MicroSD, USB Type-C Mini Travel Dock, 12" / 30cm Cable - USB C Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - HDMI - 1GbE
Docking station
Docking Interface
Video Interfaces
HDMI
11.2 cm x 5 cm x 1.2 cm
75 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
11.2 cm
5 cm
1.2 cm
75 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
USB 2.0, USB 3.0, USB 3.1 Gen 1, USB4, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Slots
1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB-C 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
Input Device
SD card reader, microSD card reader
1 x USB-C cable - integrated - 30 cm
100W power delivery, UASP transfer protocol, Preboot Execution Environment (PXE) support, HDR10 support, HDR support, DisplayPort Alt Mode, full duplex support, portable
Plug and Play, DisplayPort 1.4, USB Power Delivery 3.0, FCC, RoHS, WEEE
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple iPadOS, Android, Linux 3.5.x or later LTS versions only, Google Chrome OS
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
200 g
70 °C
GTB7 StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.98
GTB7 StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.72
GTB7 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GTB7 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
GTB7 StarTech.com USB C Multiport Adapter 2 HDMI In Stock £66.71
GTB7 StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £30.95
GTB7 StarTech.com USB-C Multiport Adapter In Stock £70.29
GTB7 StarTech.com USB-C Multiport Adapter 4K60Hz In Stock £38.62
GTB7 StarTech.com USB C Multiport Adapter In Stock £85.11
GTB7 StarTech.com USB-C Multiport Adapter, HDMI In Stock £33.04
GTB7 StarTech.com USB-C Multiport Adapter, HDMI In Stock £29.25
GTB7 StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.01
GTB7 StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £28.05
GTB7 StarTech.com USB-C Speakerphone Dock In Stock £81.07
GTB7 StarTech.com USB-C Triple-Monitor Adapter In Stock £90.11
GTB7 StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.56
GTB7 StarTech.com USB-C Triple-Monitor Adapter In Stock £94.35
Device Type: Laptop
Colour: Grey
