Connect DVI capable devices to HDMI -enabled devices and vice versa. The HDMIDVIMF HDMI to DVI Cable Adapter features one HDMI male connector and one DVI-D female connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
- StarTech.com HDMI Male to DVI Female - HDMI to DVI-D Adapter - Bi-Directional - DVI to HDMI (HDMIDVIMF) - adapter
- Cable
- Adapter
- TMDS Links
- Dual link
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - female
- Limited lifetime warranty
- Designed For
- P/N: BNDDKT30CAHV, CDP2DVIMM2MB, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVIMM6X10, MST30C2DPPD, MSTCDP122HD, SV211HDUC, SV221HUC4K, SV231DHU34K6, SV231HU34K6, SV431HU34K6, USB3DDOCKFT, USB3DOCKH2DP, USB3SMDOCK4K
- Cable Type
- Adapter
- TMDS Links
- Dual link
- Black
- Connector
- 19 pin HDMI Type A - male
- 24+1 pin digital DVI - female
- Limited warranty - lifetime
- Designed For
- P/N: 45PATCH25WH, BNDDKT30CAHV, CDP2DVIMM2MB, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMIPNLFM3, MST30C2DPPD, MSTCDP122HD, SV211HDUC, SV221HUC4K, SV231DHU34K6, SV231HU34K6, SV431HU34K6, USB3DDOCKFT, USB3DOCKH2DP, USB3SMDOCK4K, USB3SMDOCKHV
