Add HDMI, Gigabit Ethernet, USB-A, and USB-C ports (5Gbps) to your laptop through a single USB Type-C cable. Expand the connectivity of your USB-C equipped laptop, wherever you go. With this USB-C adapter, you can create a powerful workstation, providing support for an Ultra HD 4K monitor, a wired network connection, USB-A device and a USB-C device.
Ideal for mobile use, the USB-C multiport adapter is the perfect accessory for your Dell Precision, Dell XPS, MacBook or other USB Type-C laptop. Since it uses USB-C, the adapter is Thunderbolt 3 port compatible, to connect to your Thunderbolt 3 equipped laptop.
When coupled with your laptop, this USB-C adapter makes it easy to set up a dual-monitor workstation. It offers an HDMI port that supports 4K Ultra HD 4096 x 2160p with audio to connect a high-resolution monitor, plus it supports 3840 x 2160p resolution. When traveling, you can use an HDMI port-equipped television in a hotel room as a second display. The travel adapter is also ideal for quick setups in conference rooms or boardrooms, to deliver engaging presentations.
The USB-C multiport adapter ensures reliable wired network access with a Gigabit Ethernet port, which is ideal for areas with limited Wi-Fi access such as in classrooms, office buildings and hotels.
The multiport adapter provides a versatile way to connect USB devices to your port-limited laptop. Connect an existing device, like your mouse or a flash drive, to the USB Type-A port. With the USB-C port, you are future-ready to add a USB-C device.
The bus-powered multiport adapter is portable and compact, tucking easily your laptop bag. Since it consolidates multiple ports into a single adapter, you don't need to bring along multiple single-function adapters. The adapter also features a built-in USB-C cable, which means one less cable to carry. Installation is fast and simple, with native support in most operating systems.
Note: Your USB-C equipped host laptop must support video (DP Alt Mode) to work with this adapter. The adapter does not support USB Power Delivery.
Add a 4K UHD Monitor
With HDMI output, this USB-C multiport adapter makes it easy to expand your virtual workspace onto an external 4K HDMI monitor. The adapter supports resolutions up to 4096 x 2160p (24Hz) or 3840 x 2160p (30Hz), as well as audio. -
Reliable Network Access
The USB-C multiport adapter ensures a reliable wired network connection with a Gigabit Ethernet port, which is ideal for areas with limited Wi-Fi access such as in classrooms, office buildings and hotels. -
Connect Your USB Devices Easily
With two USB 3.0 ports (1x USB-A, 1x USB-C) you get access to traditional USB Type-A devices, as well as newer USB-C devices you add in the future. -
Bring Productivity with You Wherever You Go
With its compact design and bus-powered performance, the portable multiport adapter is easy to take with you anywhere you take your laptop. The adapter features a pre-attached USB-C cable, so you have one less cable to carry when you're on the move. -
The StarTech.com Advantage for Docking Stations
• Maximum compatibility - StarTech.com has a docking station to fit every operating system, laptop brand, and connectivity need •Text | Get more done faster - More ports and more displays maximize end user connectivity and productivity •Text | Quick installation - eliminate deployment headaches that waste time and frustrate end users •Text | IT Grade quality - trusted by IT pros around the world for our rigorous in-house product testing, robust compliance, and lifetime multilingual technical support The DKT30CHD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: Your USB-C equipped host laptop must support video (DP Alt Mode) to work with this adapter. The adapter does not support USB Power Delivery.
- StarTech.com USB C Multiport Adapter, Portable USB-C Mini Dock 4K HDMI Video, Gigabit Ethernet, USB 3.0 Hub (1x USB-A 1x USB-C), USB Type-C Multiport Adapter, Thunderbolt 3 Compatible - USB-C Travel Dock (DKT30CHD) - docking station - USB-C / Thunderbolt 3 - HDMI - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 6.2 cm x 6.5 cm x 1.5 cm
- 52 g
- Black
- Networking
- Gigabit Ethernet
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 6.2 cm
- 6.5 cm
- 1.5 cm
- 52 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz
- Data Link Protocol
- Gigabit Ethernet
- USB 3.0, USB 3.1 Gen 1
- 1 x USB-C 3.1 Gen 1 - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - integrated - 34 cm
- USB powered, full duplex support, auto MDIX support, plastic housing
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- OS Required
- Google Chrome OS, Apple MacOS X 10.10 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Width
- 14.5 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 168 g
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.47 |
StarTech.com USB-C Multifunction Adapter | In Stock | £48.02 |
StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £46.74 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £37.34 |
StarTech.com 2m 6ft USB 2.0 USB-C Cable | In Stock | £11.21 |
StarTech.com USB-C to 4K HDMI Adapter w/ PD | In Stock | £20.64 |
StarTech.com USB-C Adapter - PD - Silver | In Stock | £27.52 |
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £17.50 |
StarTech.com 0.5m USB 2.0 USB C Cable | In Stock | £9.20 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £19.60 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.23 |
StarTech.com USB C Adapter - 4K HDMI, GbE | In Stock | £26.78 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £25.92 |
StarTech.com 1m Right Angle USB C Cable | In Stock | £11.21 |
StarTech.com 3m USB 2.0 Type C Cable | In Stock | £13.00 |
StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £124.67 |
StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB | In Stock | £38.52 |
StarTech.com USB-C Adapter with HDMI & VGA | In Stock | £33.69 |
StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock | In Stock | £61.81 |
StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock | In Stock | £23.87 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £32.46 |
StarTech.com USBC Multiport Adapter 4K HDMI | In Stock | £27.44 |
StarTech.com USB C Multiport Adapter PD, 4K | In Stock | £20.92 |
StarTech.com USB-C Multiport Adapter HDMI | In Stock | £55.49 |
StarTech.com USB C Multiport Adapter | In Stock | £23.87 |
StarTech.com Multiport Adapter HDMI/VGA | In Stock | £59.05 |
StarTech.com USB C Multiport Adapter, 4K | In Stock | £33.46 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £47.66 |
StarTech.com USB C Mini Dock 4K HDMI | In Stock | £42.13 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £45.76 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £66.71 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £30.95 |
StarTech.com USB C Dock DP 4K30Hz or VGA | In Stock | £94.14 |
StarTech.com USB-C Multiport Adapter | In Stock | £70.29 |
StarTech.com USB C Multiport Adapter | In Stock | £85.11 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £33.04 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £29.25 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £179.82 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £43.01 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £28.05 |
StarTech.com USB-C Speakerphone Dock | In Stock | £81.07 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £90.11 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £51.56 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £94.35 |
