USB-C Multiport Adapter - 4k 60Hz HDMI 2.0b - 100W Power Delivery Passthrough - 4-Port USB Hub.
Enhance Productivity
The portable docking station connects your laptop to a 4K 60Hz HDMI monitor (4096 x 2160p) to create a powerful workstation. It can also connect to an ultrawide monitor. -
Connect Your Devices
The USB-C to USB 3.1 Gen 1 hub gives you three USB-A ports to connect your legacy USB devices, plus one shared USB-C port for either power delivery pass through. -
Charge Your Laptop and Peripherals
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT30CHPD3 is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
- StarTech.com USB C Multiport Adapter, USB-C to HDMI 2.0b 4K 60Hz (HDR10), 100W Power Delivery Pass-Through, 4-Port 5Gbps USB 3.0 Hub, USB Type-C Mini Dock, with 12" (30cm) Attached Cable - Thunderbolt 3 Compatible (DKT30CHPD3) - docking station - USB-C - HDMI
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- 4.5 cm x 3 cm x 1.3 cm
- 93 g
- Black & grey
- 3-year warranty
- Product Type
- Docking station
- 4.5 cm
- 3 cm
- 1.3 cm
- 93 g
- Enclosure Colour
- Black & grey
Video
- Max Resolution Details
- 4K - 60 Hz (DisplayPort 1.4 over USB-C) , 4K - 30 Hz (DisplayPort 1.2 over USB-C)
- 1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB 3.2 Gen 1 with Battery Charging 1.2 - 9 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 4K Ultra HD, bus powered, Parade PS176 chipset, VLI VL102 chipset, VLI VL817 chipset
- FCC, RoHS, WEEE, RCM
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS
- Additional Requirements
- Must support DisplayPort over USB-C or DP Alt Mode
- Limited warranty - 3 years
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 126 g
- 0 °C
- 45 °C
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £17.50 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £19.60 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.63 |
StarTech.com Multiport Adapter HDMI/VGA | In Stock | £59.35 |
