This USB-C multiport adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI or HDMI display. The adapter combines multiple video outputs into a single adapter, for an all-in-one connectivity solution. This adapter only connects to one display at a time.
All-in-one video?connectivity, with?travel in?mind
Avoid the hassle of carrying different adapters for different displays with this 3-in-1?USB-C adapter. With VGA, DVI and?HDMI?output, you can connect your laptop to virtually any display. -
Astonishing?picture quality
The HDMI?output?on this?USB-C video?adapter?supports?UHD 4K resolutions,?providing four times the picture quality of high-definition 1080p.?All of?the outputs (HDMI, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200. -
Maximum?portability
The convenient plug-and-play?USB-C dongle?is?the perfect?travel accessory. Fitting easily into your laptop bag,?and offering three video output options,?the USB-C display adapter is?an ideal?solution for Bring Your Own Device (BYOD) applications, wherever you go.
- StarTech.com 4K USB C to HDMI, VGA & DVI Multi Port Video Display Adapter for Mac / Windows Laptop & Monitor (CDPVGDVHDBP) - adapter - HDMI / DVI / VGA / USB - 15 cm
- Cable
- Adapter - HDMI / DVI / VGA / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 15 cm
- Black
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
- Displayport 1.2/Thunderbolt 3
- Active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
- 3-year warranty
- Cable Type
- Adapter active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
- Interface Supported
- Length
- 15 cm
- DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- Connectors
- 19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
- FCC, RoHS
- 4.5 cm
- 8.5 cm
- 1.5 cm
- 51 g
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 55 g
- Limited warranty - 3 years
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com USB-C Multifunction Adapter | In Stock | £47.42 |
StarTech.com USB-C Adapter - PD - Silver | In Stock | £47.42 |
StarTech.com USB-C to VGA, DVI or HDMI | In Stock | £38.67 |
StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB | In Stock | £38.47 |
StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable | In Stock | £25.95 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.36 |
StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £32.08 |
StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock | In Stock | £23.84 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £32.06 |
StarTech.com USBC Multiport Adapter 4K HDMI | In Stock | £24.65 |
StarTech.com USB-C Multiport Adapter HDMI | In Stock | £53.20 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.49 |
StarTech.com Multiport Adapter HDMI/VGA | In Stock | £20.09 |
StarTech.com USB C Multiport Adapter 4K | In Stock | £23.49 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £33.64 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £65.89 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £30.58 |
StarTech.com USB-C Multiport Adapter | In Stock | £22.01 |
StarTech.com USB C Multiport Adapter | In Stock | £84.39 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £28.98 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £25.65 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £148.72 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £43.75 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £27.87 |
StarTech.com USB-C Speakerphone Dock | In Stock | £79.25 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £78.42 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £47.68 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £82.13 |
