StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable
Quicklinx: F2HKWS00 Mfr#: CDP2HDVGA
More than 50 In Stock
£32.60 ex VAT
£39.12 inc VAT
This USB-C to VGA and HDMI adapter offers a portable solution for connecting your USB Type-C laptop to a VGA or HDMI display. The multiport video adapter also works as a splitter, enabling you to simultaneously output an identical video signal to two separate monitors (1 x HDMI and 1 x VGA).
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. With VGA, and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
The HDMI output on this USB-C video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1200.
The USB-C video adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
  • Two-in-One Video Connectivity with Travel in Mind
    Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. With VGA, and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport adapter. The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
  • Ultra HD 4K 30Hz Resolution
  • Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
    The USB-C video adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices. CDP2HDVGA is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB-C to VGA and HDMI Adapter - 2-in-1 - 4K 30Hz - Space Grey - Windows & Mac Compatible (CDP2HDVGA) - external video adapter - IT6222 - space grey
External video adapter
Bus Type
USB-C
Graphics Engine
IT6222
Max Resolution
3840 x 2160
Max Resolution Details
HDMI: 3840 x 2160 / VGA: 1920 x 1200
VGA (female connector) , HDMI output (female connector)
6.2 cm x 3.6 cm x 1.6 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Graphics Engine
IT6222
Max Resolution
3840 x 2160 at 30 Hz
HD/4k Ready, 5.1 surround sound
USB-C cable - 15.24 cm
FCC, RoHS, WEEE
6.2 cm
3.6 cm
1.6 cm
90 g
Enclosure Colour
Space grey
Limited warranty - 3 years
45 °C
5 - 90%
F2HK StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £59.56
F2HK StarTech.com USB-C to VGA, DVI or HDMI In Stock £41.85
F2HK StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £48.81
F2HK StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £39.44
F2HK StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video In Stock £23.27
F2HK StarTech.com Mini DisplayPort to HDMI VGA Adapter - 4K 60Hz In Stock £23.91
F2HK StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £22.45
F2HK StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter In Stock £33.34
F2HK StarTech.com USB C Multiport Video Adapter - VGA or DisplayPort - HDR 4K60 - Display Adapter In Stock £16.89
F2HK StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £32.99
