A flexible solution with an open SFP slot
The open SFP slot enables you to use your preferred SFP transceiver module to meet your networking needs - use an SFP with your desired wavelength, distance, and connection type to achieve an efficient network solution. (SFP sold separately.) -
Secure fiber-to-the-desk connectivity
This USB to fiber-optic converter provides reliable fiber connectivity while protecting your network from problems with electronic interference - a common issue with RJ45 networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks for sensitive information, without compromising network speed and reliability. -
Easy portability
Compact and portable, this USB 3.0 to fiber-optic converter is powered directly from the USB port. -
Plug and play
Get up and running quickly. The USB to fiber-optic converter supports certified drivers for Windows, Mac and Linux. Once the adapter is plugged into a USB port, you simply install the drivers and the adapter is ready to transmit over a fiber network.
- StarTech.com USB 3.0 to Fiber Optic Converter - USB to Open SFP Adapter - Gigabit Network Adapter Multi Mode(MMF)/Single Mode Fiber(SMF) (US1GA30SFP) - network adapter - USB 3.0 - 1000Base-LX/1000Base-SX x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 5.5 cm 2 cm
- Length
- 26 cm
- 100 g
- Cabling Type
- Ethernet 1000Base-SX
- Data Link Protocol
- GigE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- IEEE 802.3z, IEEE 802.1Q
- Black
- System Requirements
- Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.9 - 10.14
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet
- 1 Gbps
- Capacity
- Status Indicators
- Power, link/activity
- Full duplex capability, USB powered, Jumbo Frames support, plastic housing
- 1 x 1000Base-LX/SX - SFP (mini-GBIC) - female
- Cables Included
- 1 x USB cable (integrated) - 19.5 cm
- FCC, RoHS, WEEE
- Black
- OS Required
- 5.5 cm
- 2 cm
- Length
- 26 cm
- 100 g
- Shipping Weight
- 120 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 90%
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £116.66 |
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £88.19 |
StarTech.com USB 3 to Fiber Optic Converter | In Stock | £210.49 |
StarTech.com USB 3 Fiber Converter Open SFP | In Stock | £173.24 |
StarTech.com USB 2.0 to Fiber Converter | In Stock | £122.96 |
StarTech.com USB C to Fiber Optic Converter | In Stock | £177.89 |
