StarTech.com 1000Base-LX SFP - SM LC- 10 km
Quicklinx: D1V9WS00 Mfr#: SFP1000LXST
Type: Modules
£40.34 ex VAT
£48.40 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over single-mode fiber, with this SFP module. This 1000Base-LX SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 1Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable Gigabit connectivity over single-mode fiber for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi.) and 1310 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
  • Reliable connectivity
    The MSA Uncoded Compatible SFP Module features dual LC single-mode connectors, ensuring a stable and efficient connection for your networking needs.
  • Wide operating range
    This module functions effectively in a temperature range of 0°C to 70°C and a humidity range of 5% to 95%, making it suitable for various settings.
  • High data transfer rate
    With a data transfer rate of 1.25 Gbps, this transceiver module supports smooth data communication for optimal network performance.
  • Long-distance support
    The module can transmit data over distances of up to 10 km, allowing for flexible network designs without compromising on speed.
  • Advanced monitoring capabilities
    This product includes features like Digital Optical Monitoring and Digital Diagnostics Monitoring to enhance performance management and reliability.
StarTech.com MSA Uncoded Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode (SMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM, Mini GBIC Module - Lifetime Warranty (SFP1000LXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
1.39 cm x 5.84 cm x 1.26 cm
30 g
P/N: US1GA30SFP, US1GC30SFP
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-LX - LC single-mode x 2
FCC, RoHS, WEEE, MSA, RCM
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
Type: Modules
