StarTech.com USB 2.0 to Fiber Converter
Quicklinx: DFR8WS00 Mfr#: US100A20FXSC
£134.93 ex VAT
£161.91 inc VAT
This USB to fiber optic converter lets you utilize the USB 2.0 port on your laptop or tablet to provide a secure fiber network connection.
  • Secure connectivity
    For reliable fiber connectivity, this converter protects your network from problems with electronic interference.
  • Easy portability
    Compact and portable, this converter is powered directly from the USB port, making it easy to connect when you're on the go.
StarTech.com USB to Fiber Optic Converter, 100Mbps, USB 2.0 to Fiber Network Adapter, 100BASE-FX SC Female Duplex Multimode Fiber/MMF Compatible, 2Km, Compact USB to Fiber LAN Adapter - USB to LAN Adapter (US100A20FXSC) - network adapter - USB 2.0 - 100Base-FX/100Base-SC x 1
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
5.5 cm x 26 cm x 2 cm
100 g
Cabling Type
Ethernet 100Base-FX, Ethernet 100Base-SC
100Mb LAN
Max Transfer Distance
2 km
Data Transfer Rate
100 Mbps
ASIX AX88772C
IEEE 802.1Q, IEEE 802.3x
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions
Network adapter
External
USB 2.0
Ports
Wired
Cabling Type
Fast Ethernet
Data Transfer Rate
100 Mbps
2 km
Optical Wave Length
1310 nm
Status Indicators
Power, link/activity
WOL, USB powered
Processor / Memory
ASIX AX88772C
1 x 100Base-FX/100Base-SC - SC - female - x 2
Plug and Play, FCC, RoHS
5.5 cm
26 cm
2 cm
100 g
60 °C
5 - 90%
DFR8 StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km In Stock £71.49
DFR8 StarTech.com USB 3 Fiber Converter Open SFP In Stock £162.25
DFR8 StarTech.com USB 2.0 to Fiber Converter In Stock £134.93
DFR8 StarTech.com USB C to Fiber Optic Converter In Stock £185.15
Type: Fibre Converter
