This desk mount arm lets you mount two monitors onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
Free up desk space
With a stable crossbar design, the dual computer screen stand lets you create more usable work space by mounting your monitors side by side on a single base. The ergonomic monitor mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall. The built-in USB 3.0 ports at the base provide a convenient way to connect your peripherals. -
Optimal viewing
The multi-monitor mount features one-touch height adjustment. The smooth +/- 10° tilt motion and +/- 90° swivel make it easy to find the optimal viewing angle. You can also rotate each display 180° for portrait or landscape viewing and keep your displays at the same height with the horizontal crossbar. -
Flexible installation
The monitor mount is easy to install, with the desk clamp or grommet mount. Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
- StarTech.com Desk Mount Dual Monitor Arm with USB & Audio, Slim Full Motion Adjustable Dual Monitor VESA Mount for 32" Displays (8kg/screen), Ergonomic Articulating, Desk Clamp or Grommet - One-touch Adjustment (ARMSLIMDUAL2USB3) mounting kit - adjustable arm - for 2 monitors - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 83.2 cm x 56.9 cm x 59.5 cm
- Tilt
- -10° to 10°
- Rotation
- 180°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, rotation
- 8.46 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- Up to 32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Aluminium
- Black
- Package Content
- 2 x VESA monitor mount, baseplate, crossbar, 8 x M4x12 screws, handle, hex key (4mm), hex key (3mm), grommet plate, 8 x washers, hex key (6mm), cable management clip, 8 x M5x12 screws, 2 x monitor arms, clamp base, adhesive pads, 4 x countersunk screws
- 2-year warranty
- 83.2 cm
- 56.9 cm
- 59.5 cm
- 8.46 kg
- Material
- Aluminium
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- Up to 32"
- Tilt
- -10° to 10°
- Rotation
- 180°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 89.5 cm x 22.5 cm x 15 cm / 8.78 kg
- Limited warranty - 2 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £136.05 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £161.64 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £212.73 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £68.85 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £191.88 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £98.19 |
StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating | In Stock | £97.31 |
StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm | In Stock | £191.34 |
StarTech.com Desk Mount Monitor Arm/Max 32" | In Stock | £161.49 |
StarTech.com Dual Monitor Desk Mount | In Stock | £208.89 |
StarTech.com Six-Monitor Desk Mount/Max 32" | In Stock | £277.24 |
