StarTech.com Dual Monitor Desk Mount
Quicklinx: J4KHWS00 Mfr#: H2M1AS2-MONITOR-ARM
Hurry, only 1 left in stock!
£208.89 ex VAT
£250.66 inc VAT
This crossbar monitor desk mount is designed to support up to two 27-inch displays, creating an ergonomic multi-monitor setup that provides an extensive viewing area for productivity. The built-in handle enables moving all monitors simultaneously, while the spring-assisted arm allows multiple adjustments to suit different ergonomic needs. The mechanical spring arm enables a toolless height adjustment range of 7.9-20.8in (20.2-52.9cm)) with effortless one-touch motion. The maximum arm extension is 22.6in (57.4cm) and the total weight capacity is 33lb (15kg). This monitor mount is ideal for bezel-less or slim bezel displays, creating a more extensive and seamless viewing experience that enhances multitasking and productivity. The VESA mounts can slide along the crossbar, allowing for further adjustments. The monitors' VESA mounts support +/-30° swivel, +65°/-15° tilt, and 360° screen rotation for portrait or landscape orientation. The computer monitor mount is backed for 10 years. The arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
  • Height Adjustment with One Smooth Motion
    The mechanical spring arm enables toolless height adjustment of up to 12.9in (32.7cm) with effortless one-touch motion. The maximum arm extension is 22.6in (57.4cm) and a total weigh capacity of 33lb (15kg).
  • Visual Experience
  • Range of Motion
    The monitors' VESA mounts enable support +/-15° swivel, +65/-15° tilt, and 360° screen rotation for portrait/landscape orientation.
  • Cable Management
    To maintain an organized workspace, the arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
StarTech.com Desk Mount Dual Monitor Arm w/ Crossbar, Up To 27" Displays mounting kit - articulating, mechanical spring - for 2 LCD displays - black - TAA Compliant
Mounting kit (articulating, mechanical spring) - desk-mountable
Adjustable Depth
10.4-63 cm
Adjustable Height
20.2-52.9 cm
Tilt
-15° to 5°
Rotation
360°
Swivel
-180° to 180°
Adjustments
Height, tilt, swivel, rotation, pivot
Recommended Use
2 LCD displays
Recommended Display Size
17"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
30 kg
Material
Steel, plastic
TAA Compliant
Package Content
Monitor arm, 2 x VESA monitor mount, EVA cushion, 8 x VESA screws, cable clip, M3 hex key, M6 hex key, crossbar, 2 x crossbar endcaps, 4 x M6x12 screws, 5 x M6 cap nuts, grab handle
10 years warranty
Adjustable Depth
10.4-63 cm
Adjustable Height
20.2-52.9 cm
Material
Steel, plastic
Package Content
AV Furniture
Mounting kit
Design
Articulating, mechanical spring
Recommended Use
2 LCD displays
Placing / Mounting
Desk-mountable
Cable Management
Cable management channel
17"-27"
Tilt
-15° to 5°
Rotation
360°
Swivel
-180° to 180°
Adjustments
Max Load Weight
30 kg
TAA Compliant
Assembly Required
Dimensions & Weight Details
80 cm x 35.2 cm x 17.1 cm / 6.3 kg
Limited warranty - 10 years
J4KH StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.59
J4KH StarTech.com 24" Monitor Privacy Screen In Stock £79.81
J4KH StarTech.com 25" Monitor Privacy Screen In Stock £71.91
J4KH StarTech.com Desk Mount Monitor Arm/Max 32" In Stock £161.49
