StarTech.com Desk Mount Monitor Arm/Max 32"
Quicklinx: J4KGWS00 Mfr#: H1M1AG2-MONITOR-ARM
14 In Stock
£157.56 ex VAT
£189.07 inc VAT
This monitor desk mount is designed to support up to a 32-inch ultrawide display. The mechanical spring arm enables a toolless height adjustment range of 7.7 to 20.6in (19.7 to 52.4cm) with effortless one-touch motion. The maximum arm extension is 21in (53.5cm) and the total weight capacity is 22lb (10kg). The monitor arm comes pre-assembled and includes a VESA monitor plate that uses thumb screws to securely mount the monitor quickly and without additional tools. The monitor VESA mounts support +/-30° swivel, +90°/-15° tilt, and 360° screen rotation for portrait or landscape orientation. The computer monitor mount is backed for 10 years. The arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup.
  • Quick and Toolless Installation
  • Height Adjustment with One Smooth Motion
    The mechanical spring arm enables toolless height adjustment with a range from 7.7 to 20.6in (19.7 to 52.4cm) with effortless one-touch motion. The maximum arm extension is 21in (53.5cm) with a total weight capacity of 22lb (10kg).
  • Range of Motion
    The monitor's VESA mounts enable support of +/-15° swivel, +90/-15° tilt, and 360° screen rotation for portrait/landscape orientation.
  • Cable Management
    To maintain an organized workspace, the arms feature a cable management channel along the underside to keep cables out of sight, reducing clutter and contributing to a tidy setup. The monitor mount is TAA-compliant and is backed for 10-years including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Desk Mount Monitor Arm, Up To 32" Display, C-Clamp, TAA mounting kit - for Monitor - black - TAA Compliant
Mounting kit - desk-mountable
Mounting Components
Articulating arm, C-clamp
12 cm x 60 cm
Adjustable Height
20.2-52.9 cm
Tilt
-15° to 90°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Height, rotation, tilt, swivel, extension
3.5 kg
Recommended Use
Monitor
Recommended Display Size
17"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Plastic, steel
TAA Compliant
Package Content
2 bases, 4 x VESA screws, spring arm assembly, VESA monitor mount, cable clip, M3 hex key, M6 hex key
10 years warranty
12 cm
60 cm
Adjustable Height
20.2-52.9 cm
3.5 kg
Material
Plastic, steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Cable Management
Cable management channel
17"-27"
Tilt
-15° to 90°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Max Load Weight
10 kg
TAA Compliant
Dimensions & Weight Details
54.7 cm x 34 cm x 16.4 cm / 3.5 kg
Limited warranty - 10 years
J4KG StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
J4KG StarTech.com 24" Monitor Privacy Screen In Stock £77.87
J4KG StarTech.com 27" Monitor Privacy Screen In Stock £101.64
J4KG StarTech.com 25" Monitor Privacy Screen In Stock £70.15
