StarTech.com Monitor Mount - USB Passthrough
Quicklinx: C17XWS00 Mfr#: ARMSLIMDUO
Hurry, only 2 left in stock!
£157.69 ex VAT
£189.22 inc VAT
Increase productivity by mounting two monitors up to 30", with full-motion articulation. Enhance productivity and free up valuable space with the ARMSLIMDUO Dual-Monitor Arm. Two independent arms make it easy to adjust your dual-monitor setup, plus two USB pass-through ports and headset plugs provide easy accessibility to ports.
When you mount your displays on a dual-monitor arm above your desk or table surface, you can adjust your display height, position and viewing angles easily to create a more comfortable and ergonomic work environment. You also get the added benefit of reclaiming valuable workspace by clearing monitor stands off your desk, plus the cable management system keeps cables neatly tucked away.
The dual-arm monitor mount holds two 12" to 30" monitors, side-by-side, with ease. Each arm supports up to 8.0 kg (17.6 lb.) of weight.
The ARMSLIMDUO gives you easy access to two USB pass-through ports and two audio ports located at the front of the base. The ports let you conveniently extend the ports on your PC or laptop, using the integrated cables. This lets you plug in your microphone, headset or USB devices, without having to reach around to access the ports on your computer. It also gives you a cleaner cable setup, which adds to a more productive, less cluttered work space.
The desk-mount monitor arms offer a full range of motion on several axes, letting you tilt, pan and rotate your monitors to adjust your viewing angle any time to suit your changing needs. To view longer pages or blocks of code without scrolling, the arms also support landscape-to-portrait display rotation for each monitor.
The spring-assisted height adjustment makes raising or lowering your monitors effortless. You can also adjust the tension to your own preference.
With its durable aluminum construction, the ARMSLIMDUO securely holds two monitors using a standard VESA mount. The C-clamp makes it easy to install the dual-monitor arm mount to your desk or table. The fast insert function makes it easy to attach your monitor.
  • Flexible adjustment options
    The arm features height, pan, and tilt adjustments, allowing users to customize their display positions for improved ergonomics and comfort.
  • Multiple display compatibility
    Designed for dual monitors, it supports display sizes from 12 to 32 inches, making it suitable for a variety of setups.
  • Integrated cable management
    The built-in cable management system keeps wires organized, reducing clutter and enhancing the overall appearance of your workstation.
  • Durable construction
    Made from aluminum, this monitor arm provides a reliable solution for mounting displays without compromising stability.
  • Versatile positioning
    With 360-degree rotation and 180-degree swivel, it allows users to easily adjust monitors to achieve the perfect viewing angle.
StarTech.com Desk Mount Dual Monitor Arm - One-Touch Height Adjustment (ARMSLIMDUO) mounting kit - adjustable arm - for LCD display - black
Mounting kit (adjustable arm) - desk-mountable
1.1 m x 1.4 cm x 45 cm
Tilt
-90° to 85°
Rotation
360°
Swivel
180°
Adjustments
Height, pan, tilt
6.1 kg
Recommended Use
LCD display
Recommended Display Size
12"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium
Package Content
2 x VESA monitor mounts, 8 x M4x12 screws, 8 x M4x30 screws, 8 x plastic spacers, M4 allen key, M5 allen key, 8 x M6x12 screws, 4 x M8x12 screws
P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, PXT101YUK, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
1.1 m
1.4 cm
45 cm
6.1 kg
Material
Aluminium
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Desk-mountable
Cable Management
12"-32"
Tilt
-90° to 85°
Rotation
360°
Swivel
180°
Adjustments
Height, pan, tilt
Max Load Weight
8 kg
Adjustable Feet
C17X StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £65.29
