StarTech.com StarTech.com Desk Mount Dual Monitor Arm - 2x USB 3.0 ports
Quicklinx: FTWMWS00 Mfr#: ARMSLIMDUAL2USB3
Accessory Type: Bracket
15 In Stock
£117.00 ex VAT
£140.40 inc VAT
This desk mount arm lets you mount two monitors onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
  • Free up desk space
    With a stable crossbar design, the dual computer screen stand lets you create more usable work space by mounting your monitors side by side on a single base. The ergonomic monitor mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall. The built-in USB 3.0 ports at the base provide a convenient way to connect your peripherals.
  • Optimal viewing
    The multi-monitor mount features one-touch height adjustment. The smooth +/- 10° tilt motion and +/- 90° swivel make it easy to find the optimal viewing angle. You can also rotate each display 180° for portrait or landscape viewing and keep your displays at the same height with the horizontal crossbar.
  • Flexible installation
    The monitor mount is easy to install, with the desk clamp or grommet mount. Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
StarTech.com Desk Mount Dual Monitor Arm with USB & Audio, Slim Full Motion Adjustable Dual Monitor VESA Mount for 32" Displays (8kg/screen), Ergonomic Articulating, Desk Clamp or Grommet - One-touch Adjustment (ARMSLIMDUAL2USB3) mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
83.2 cm x 56.9 cm x 59.5 cm
Tilt
-10° to 10°
Rotation
180°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
8.46 kg
Recommended Use
2 monitors
Recommended Display Size
Up to 32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium
Package Content
2 x VESA monitor mount, baseplate, crossbar, 8 x M4x12 screws, handle, hex key (4mm), hex key (3mm), grommet plate, 8 x washers, hex key (6mm), cable management clip, 8 x M5x12 screws, 2 x monitor arms, clamp base, adhesive pads, 4 x countersunk screws
83.2 cm
56.9 cm
59.5 cm
8.46 kg
Material
Aluminium
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
Up to 32"
Tilt
-10° to 10°
Rotation
180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
89.5 cm x 22.5 cm x 15 cm / 8.78 kg
FTWM StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
FTWM StarTech.com Monitor Mount - USB Passthrough In Stock £161.64
FTWM StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
FTWM StarTech.com Vertical Dual Monitor Mount In Stock £68.85
FTWM StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £191.88
FTWM StarTech.com Desk Mount Dual Monitor Arm - Crossbar In Stock £98.86
FTWM StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating In Stock £97.96
FTWM StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm In Stock £191.34
FTWM StarTech.com Desk Mount Monitor Arm/Max 32" In Stock £161.49
FTWM StarTech.com Dual Monitor Desk Mount In Stock £208.89
FTWM StarTech.com Six-Monitor Desk Mount/Max 32" In Stock £277.24
