StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black
Quicklinx: 8TJ8WS00 Mfr#: ST4300MINU3B
Type: USB Hub
Interface: SuperSpeed USB 3.0
Ports: 4
Form Factor: External
  • Windows 8 (32/64 bits)
More than 50 in stock
£18.82 ex VAT
£22.58 inc VAT
Add four external USB 3.0 ports to your notebook or Ultrabook with a slim, portable hub. The ST4300MINU3B Portable 4 Port SuperSpeed Mini USB 3.0 Hub (Black) lets you expand your USB connectivity by turning a single USB 3.0 port into four external USB 3.0 ports. The integrated cable design makes this mini USB hub the perfect accessory for your Mac / PC notebook or Ultrabook computer.
The 4 Port USB 3.0 hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age.
Ideal for home and business users who require portability, the external USB 3.0 hub is USB-powered and features a rugged, compact design with a built-in cable so no additional cables are needed to connect the hub to your system.
StarTech.com 4-Port USB 3.0 SuperSpeed Hub - Portable Mini Multiport USB Travel Dock - USB Extender Black for Business PC/Mac, laptops (ST4300MINU3B) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0
3.9 cm x 7.6 cm x 1.4 cm
38 g
Apple MacOS X 10.0 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
P/N: FCREADMICRO3, MSDREADU3CA, USB3S2ESATA3
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
Status Indicators
4 x USB 3.0 Type A , 1 x USB 3.0 Type A
1 x USB cable - 14.5 cm
FCC, RoHS
3.9 cm
7.6 cm
1.4 cm
38 g
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Type: USB Hub
Ports: 4
Stock Status: In stock
