Add four external USB 3.0 ports to your notebook or Ultrabook with a slim, portable hub. The ST4300MINU3B Portable 4 Port SuperSpeed Mini USB 3.0 Hub (Black) lets you expand your USB connectivity by turning a single USB 3.0 port into four external USB 3.0 ports. The integrated cable design makes this mini USB hub the perfect accessory for your Mac / PC notebook or Ultrabook computer.
The 4 Port USB 3.0 hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age.
Ideal for home and business users who require portability, the external USB 3.0 hub is USB-powered and features a rugged, compact design with a built-in cable so no additional cables are needed to connect the hub to your system.
 - StarTech.com 4-Port USB 3.0 SuperSpeed Hub - Portable Mini Multiport USB Travel Dock - USB Extender Black for Business PC/Mac, laptops (ST4300MINU3B) - hub - 4 ports
 - Hub - 4 ports
- Subtype
 - USB
- Ports
 - 4 x SuperSpeed USB 3.0
 - USB powered
 - USB 1.1, USB 2.0, USB 3.0
 - 3.9 cm x 7.6 cm x 1.4 cm
 - 38 g
 - Black
- System Requirements
 - Apple MacOS X 10.0 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
 - 2-year warranty
- Designed For
 - P/N: FCREADMICRO3, MSDREADU3CA, USB3S2ESATA3
 - Hub - 4 ports
- Enclosure Type
 - Desktop
- Subtype
 - USB
- Ports
 - USB powered
- Status Indicators
 - Power
 - 4 x USB 3.0 Type A , 1 x USB 3.0 Type A
 - Black
- Cables Included
 - 1 x USB cable - 14.5 cm
 - FCC, RoHS
- OS Required
 - 3.9 cm
 - 7.6 cm
 - 1.4 cm
 - 38 g
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 0 - 80%
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 60 °C
- Designed For
                        StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.00 |
                        StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £19.16 |
                        StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.25 |
                        StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £38.80 |
                        StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £29.84 |
                        StarTech.com 4 Port Portable USB 3.0 Hub | In Stock | £23.79 |
                        StarTech.com 4 Port USB C Hub with PD 2.0 | In Stock | £34.11 |
                        StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £45.82 |
                        StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £29.07 |
                        StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £39.13 |
                        StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £26.12 |
                        StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £30.29 |
                        StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £41.13 |
                        StarTech.com 7 Port USB C Hub - C to C & A | In Stock | £65.16 |
                        StarTech.com 7 Port USB-C Hub - C to C & A | In Stock | £67.97 |
                        StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £42.74 |
                        StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £25.05 |
