1000 Mbps (1 Gbps) Copper RJ-45 100 m (328 ft) Lifetime Warranty. The SFP1GEFEETST is a Juniper SFP-1GE-FE-E-T compatible copper transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
Technical Specifications:
Maximum Data Transfer Rate: 1000 Mbps (1 Gbps)
Type: Copper
Connection Type: RJ-45
Maximum Transfer Distance: 100 m (328 ft)
MTBF: 4,655,371 hours
Power Consumption: Low power consumption
Digital Diagnostics Monitoring (DDM): No
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com SFPs
All StarTech.com SFP & SFP+ transceiver modules are backed by a lifetime warranty and free lifetime multilingual technical support. StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper SFP-1GE-FE-E-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mb Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFP1GEFEETST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 10Base-T, 100Base-TX, 1000Base-T
- Data Transfer Rate
- 1.25 Gbps
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 100 m
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-1GE-FE-E-T
- 1.4 cm x 6.5 cm x 1.2 cm
- 72 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1.25 Gbps
- 100 m
- Full duplex mode
- IEEE 802.3
- 1 x Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 female
- MTBF
- 4,655,371 hours
- FCC, RoHS, REACH, MSA
- 1.4 cm
- 6.5 cm
- 1.2 cm
- 72 g
- Shipping Width
- 20.7 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 80 g
- Limited warranty - lifetime
