Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for in-wall installations or anywhere CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
Reliable connectivity
This MTP to LC Breakout Cable utilizes a fiber optic design to ensure dependable communication and data transfer in network setups. -
Versatile connector types
The cable features MTP/MPO multi-mode connectors on one end and LC multi-mode connectors on the other, allowing for a diverse range of applications. -
Compliance assurance
Constructed in compliance with OM3 standards and RoHS regulations, this cable promotes safety and environmental responsibility in networking solutions. -
Efficient core/cladding specifications
With a core/cladding diameter of 50 / 125 micron, this multimode fiber optic cable delivers optimal performance for various networking tasks. -
Easy installation process
The push/pull design of the connectors simplifies the connection process, enabling fast and reliable setup without complications.
- StarTech.com MTP to LC Breakout Cable - 30 ft / 10m - OM3 Multimode - 40Gb - Pull Tab - Plenum - MPO / MTP Connector - Fiber Optic Cable (MPO8LCPL10M) - breakout cable - 10 m - aqua
- Breakout cable - OM3
- Technology
- Fibre optic
- Type of Fibre Optics
- Multimode
- Plenum
- Length
- 10 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- MTP/MPO multi-mode - female - push/pull
- Connector (Second End)
- 8 x LC multi-mode - male - push/pull
- Aqua
- Limited lifetime warranty
- Network Cable Type
- Technology
- Fibre optic
- Multimode
- 50 / 125 micron
- Plenum
- Length
- 10 m
- 91.4 g
- Aqua
- Connector
- RoHS
StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC | In Stock | £50.89 |
StarTech.com Fiber Breakout Cable 10m MPO / MTP to LC | In Stock | £75.51 |
