StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC
Quicklinx: DXF0WS00 Mfr#: MPO8LCPL1M
Length: 1m
Colour: Aqua
£50.89 ex VAT
£61.06 inc VAT
Fan out eight fibers from a 40Gbps MPO connection to four 10Gbps LC connections. This MPO/MTP to 8x LC breakout cable lets you fan out a single 40Gbps connection from a 40GBase-SR4 QSFP+ transceiver to four 10Gbps LC SFP+ transceivers.
The push-and-pull tabs optimize accessibility and let you install or remove the connectors with one hand, without using additional tools. Plus, the slim uniboot design of the LC connectors saves space and improves cable management.
The MPO cable is housed in a plenum-rated jacket and is ideal for installations where CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
  • Efficient design
    This breakout cable features MTP/MPO on one end and LC connectors on the other, facilitating easy connection to network devices while maintaining high data integrity.
  • Flexible connectivity
    Equipped with 8 female LC connectors, the cable enables easy connection to multiple endpoints, perfect for expanding network capabilities.
  • High-speed performance
    With compliance to OM3 standards, this fiber optic cable delivers fast data rates up to 40 Gb, ensuring smooth operation in demanding network environments.
  • Safe installation
    The plenum-rated design allows for installation in air circulation spaces, adhering to safety standards while offering reliable performance.
  • Durable construction
    Constructed with 50 / 125 micron core and cladding dimensions, the cable provides robustness for long-lasting and effective signal transmission.
StarTech.com MTP to LC Breakout Cable - 3 ft / 1m - OM3 Multimode - 40Gb - Pull Tab - Plenum - MPO / MTP Connector - Fiber Optic Cable (MPO8LCPL1M) - breakout cable - 1 m - aqua
Breakout cable - OM3
Fibre optic
Type of Fibre Optics
Multimode
Plenum
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
MTP/MPO multi-mode - female - push/pull
Connector (Second End)
8 x LC multi-mode - male - push/pull
Aqua
Network Cable Type
Fibre optic
Multimode
50 / 125 micron
Plenum
Length
1 m
8.6 g
Aqua
Connector
RoHS
DXF0 StarTech.com Fiber Breakout Cable 1m MPO / MTP to LC In Stock £50.89
Length: 1m
Colour: Aqua
