The SFP10GLRMEMS is a Dell EMC SFP-10G-LRM compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 10Base-LRM compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Dell EMC SFP-10G-LRM Compatible SFP+ Module, 10GBASE-LRM, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 200m, 1310nm, DDM, Mini GBIC - Lifetime Warranty (SFP10GLRMEMS) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LRM
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 200 m
- OEM Manufacturer Equivalent Part Number
- Dell EMC SFP-10G-LRM
- 5.84 cm x 1.39 cm x 1.26 cm
- 30 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LRM
- 10GbE
- 10 Gbps
- 1310 nm
- 200 m
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
- MTBF
- 38,631,862 hours
- UL, FCC, MSA
- 1 Watt
- 5.84 cm
- 1.39 cm
- 1.26 cm
- 30 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
