StarTech.com Brocade 57-0000075-01 Compatible SFP+ MM Module - 10GBase-SR
Quicklinx: FJB8WS00 Mfr#: 57-0000075-01-ST
The 57-0000075-01-ST is a Brocade 57-0000075-01 compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Brocade 57-0000075-01 Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 300m, 850nm, DDM, Mini GBIC SFP+ Module - Lifetime Warranty (57-0000075-01-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
5.84 cm x 1.39 cm x 1.26 cm
20 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
498,745,585 hours
FCC, MSA
1.3 Watt
5.84 cm
1.39 cm
1.26 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
