StarTech.com 1U Cable Management Panel
Quicklinx: D0ZNWS00 Mfr#: CABLMANAGERH
40 left in stock
£30.74 ex VAT
£36.88 inc VAT
Use this 1U server rack cable-management panel with pass-thru routing holes to organize network server and KVM cabling in your rack. This server rack cable-management panel keeps your rack cables neatly bundled and guided, for tidier rack space. The 1U cable organizer features a combination of D-ring hooks and pass-through holes that enable you to run cables to and from your equipment through the panel and into the hooks.
The rack-cable management panel makes it easier to organize cables from the front or back of your server rack. It features five conveniently placed D-ring hooks that you can use to hold and guide cable bundles running vertically and horizontally. To bundle and route cables through the panel, the cable manager also features four holes designed to seamlessly route cables in and out of your rack.
This cable management panel saves rack space with a 1U design. Despite the panel's low-profile it still provides plenty of cable management, with a combination of five D-ring hooks and four cable holes.
Routing your cables through a panel reduces the tension that's often put on equipment ports, preventing damage to your expensive rack-mounted devices. Properly routing cables also improves airflow in your server rack, which helps to keep your equipment running at optimal temperatures to reduce the probability of damage caused by your rack overheating.
Note: Power cables may not fit through the holes on this panel.
StarTech.com 1U 19" Cable Management Organizer, D Ring Hook Network/Server Rack Cord Manager, Data Center Horizontal Wire Panel with Passthrough Holes with Mounting Hardware, EIA/ECA-310-E - 1U Ring Hook Organizer (CABLMANAGERH) - rack cable management kit - 1U - 19"
Rack cable management kit
Package Content
Cable management panel, 4 x M5 nuts, 4 x M5 screws
48.26 cm x 10.2 cm x 4.45 cm
610 g
Height (Rack Units)
1U
5-year warranty
Package Content
Height (Rack Units)
1U
48.26 cm
10.2 cm
4.45 cm
610 g
Rack Size
19"
Horizontal orientation
Limited warranty - 5 years
Stock Status: While stocks last
Stock Status: Clearance
