This 8U Open Frame Wall Mount Equipment Rack is a high quality, low cost relay rack that is easy to assemble and install into any environment. The rack can be wallmounted or installed as a free standing storage solution.
Able to accommodate common data, audio-video and telecom equipment, the open rack offers a depth of 12in; the wall mounts are positioned 16in apart (center to center), making it suitable for mounting on virtually any wall surface, based on North American wall frame stud spacing standards.
- StarTech.com 8U 19" Wall Mount Network Rack - 12" Deep 2 Post Open Frame Server Room Rack for Data/AV/IT/Computer Equipment/Patch Panel with Cage Nuts & Screws 135lb Capacity, Black (RK812WALLO) - rack - 8U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 8U
- Product Material
- Steel
- 50.5 cm x 30.8 cm x 35.6 cm
- 8 kg
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
- Product Type
- Rack
- Product Material
- Steel
- Rack Size
- 19"
- 8U
- 50.5 cm
- 30.8 cm
- 35.6 cm
- 8 kg
- Black
- Weight Limit
- 80 kg
- UL, RoHS
- Limited warranty: - 1 year
- Designed For
StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet | In Stock | £284.04 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £75.78 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £41.78 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.28 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.14 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £42.69 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £15.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £31.71 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £60.18 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £63.56 |
StarTech.com 4U 19in Steel Horizontal Wall Mountable Server Rack | In Stock | £144.35 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £37.77 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £3.39 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.09 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £44.18 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £24.99 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £63.56 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £33.88 |
StarTech.com Portable Server Rack - 9U | In Stock | £253.32 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £27.44 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £21.95 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £16.65 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £60.18 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £31.01 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £17.89 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £33.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £18.70 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £29.13 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £578.21 |
StarTech.com 19in Cable Management Panel | In Stock | £23.93 |
StarTech.com 18U Server Rack Enclosure | In Stock | £436.98 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £172.30 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £196.32 |
StarTech.com 12U Server Rack Enclosure | In Stock | £388.15 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.64 |
StarTech.com 15U Server Rack Enclosure | In Stock | £370.04 |
StarTech.com 12U Server Rack Enclosure | In Stock | £393.33 |
