This 6U (12in) high steel mounting bracket delivers a sturdy and dependable equipment storage option, allowing you to wallmount equipment for a more efficient and accessible operating environment. The mounting bracket features an all-steel design.
Durable construction
Made from high-quality steel, this bracket ensures long-lasting durability and strength to support network equipment. -
Space-saving design
Designed to be wall-mounted, it maximizes floor space and provides a tidy installation for easy access to cables and equipment. -
Standard rack compatibility
The 19-inch rack size is compliant with standards, allowing for a wide range of compatible equipment to be mounted.
- StarTech.com Wall Mount Patch Panel Bracket - 6U - 14in Deep (WALLMOUNT6) - cabinet - 6U
- Product Type
- Cabinet
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 6U
- Product Material
- Steel
- Product Type
- Cabinet
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 6U
- Black
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £36.10 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.63 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £34.98 |
StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £39.99 |
StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £54.83 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £68.51 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £45.13 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.19 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £49.48 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £56.01 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £56.64 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.15 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
StarTech.com 12U WM Bracket for 12 INCH Equipment | In Stock | £122.14 |
StarTech.com 8U WM Bracket for 12in Equipment | In Stock | £103.61 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £35.14 |
StarTech.com 18U Server Rack Enclosure | In Stock | £379.01 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £152.72 |
StarTech.com 26U Server Rack Enclosure | In Stock | £475.05 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £178.89 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £198.84 |
StarTech.com 12U Server Rack Enclosure | In Stock | £338.60 |
StarTech.com 12U Server Rack Enclosure | In Stock | £283.26 |
StarTech.com 12U Server Rack Enclosure | In Stock | £393.13 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £26.77 |
StarTech.com 4U Wall Mount Rack, 13.78in Deep, 19 inch Wall Mount Network | In Stock | £46.00 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
